Old 11-18-2016, 02:44 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Question Trim on Dynon Autopilot vs. VP-X
Both the Dynon Skyview Autopilot module and the VP-X have the capabilities to govern both the pitch and roll trim switches and servos.
Can anyone tell me if one is recommended over the other, and if so, why?
Currently, I was planning on using the VP-X capability, but only because I didn't know the Dynon AP module would do it.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 11-18-2016, 04:18 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
The difference is that if you use the trim in the Dynon AP module, we can auto trim the plane when the AP is on. If you use the VP-X, you'll need to manually trim the plane when using the autopilot.
Otherwise the features are very similar.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 11-18-2016, 05:31 PM
cdeerinck's Avatar
Question
Dynnon Support,
Does the Dynon AP module have any capability for trim position feedback or indication? I don't see any pin-outs for trim positions as the VP-X has.
~Chuck
DG-800S Sailplane
84CX Reserved
Old 11-18-2016, 06:03 PM
The module itself does not have that. It is handled by the engine monitor in our system.
No reason you can't use the VP-X for trim position and the AP control panel for trim control if you don't have our EMS. If you do have our EMS, we'd recommend the use of that as it's all battery backed up and more easily calibrated.
Dynon Avionics
425-402-0433
Old 01-05-2017, 01:17 PM
cdeerinck's Avatar
I don't think I can use the EMS, as the Ray Allen trim motors require a +2.5v reference voltage for the potentiometers to work.
I checked with Vertical Power, and I think I got possible incorrect information (in his defense, he just returned from vacation, and was catching up on a lot). I was told the position would not work if the motors were not connected to the VP-X. I tested that today, and it appears to not be the case. It works fine and was easy to calibrate and is backed up too, so I will be going that route. I think I will be using the spare EMS GPIO pins for other items.
Could you possibly answer one question I have: Will I be able to configure widgets that use the VP-X values, as I can for the EMS values? I have all the surround avionics, but not the Skyview yet, so I haven't had the chance to start in with the main config.
~Chuck
DG-800S Sailplane
84CX Reserved
Old 01-05-2017, 01:39 PM
Raymo's Avatar
Raymo Raymo is offline
Yes, you can feed the trim servos into the EMS and many do to monitor their position. Same for flaps but that requires a separate position sensor.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 01-05-2017, 01:53 PM
RV-4 RV-4 is offline
Default RAY ALLEN SERVO
I just read the above post and it got me thinking...
'' Ray Allen trim motors require a +2.5v reference voltage''
Exactly what do you mean by that??Do I have to install a resistance or something else in line when I install the servos??
I'm planning a standard Dynon AP module with a Ray Allen Servo with the applicable Relay Deck connected to an Infinity Stick Grip so that I can get the autotrim function with my Skyview...
Anything else I should know?? Electrical stuff is not my cup of tea...
Bruno
Old 01-05-2017, 02:04 PM
RV7A Flyer's Avatar
Bruno
The SV installation manual has all of this info, section 7 (figure 79 of the latest revision).
I have RA trim servos for pitch and roll, as do most others I believe, connected per the install manual to get indications on the screen, and it's always worked flawlessly.
Old 01-05-2017, 02:05 PM
Raymo's Avatar
Bruno
You won't need the relays for trim; it is handled within the AP panel. Just a relay for flaps with that setup (which is what I have).
Ray
Old 01-05-2017, 02:06 PM
bret's Avatar
bret bret is offline
I did the full Dynon setup, there is a 5 V DC output for feeding these Ray Allen position sensors, I put one on the flaps and also fed the other two trim motors, works great.
