View Poll Results: 6/7/8- do you have a functional canopy/ejection release mechanism?
I have an 8 and HAVE a mechanism to eject the canopy. 12 9.38%
I have an 8 and DO NOT HAVE a mechanism to eject the canopy. 21 16.41%
I have a 6/7 tip up and DO NOT HAVE a functioning canopy release/eject mechanism. 49 38.28%
I have a 6/7 tip up and HAVE a functioning canopy release/eject mechanism. 24 18.75%
I relocated the original 6/7 tip up canopy release/eject mechanism handle. 14 10.94%
I have a 6/7 slide and HAVE a functioning canopy release mechanism. 8 6.25%
Voters: 128. You may not vote on this poll
  #11
Old 11-18-2016, 03:05 PM
BillL BillL is offline
Originally Posted by ChiefPilot View Post
On the other hand, if you *ever* want to participate in a sanctioned IAC event you need a quick release canopy. The aircraft won't pass a tech inspection without it and that means it wouldn't be eligible to fly in such an event.
Modifying a slider can be as simple as replacing two bolts with two pip pins or similar. The tip-up is designed to be jettison-able but many builders opt to leave this out for various reasons.
For a slider, I see no downsides to making it jettison-able and mine has been that way from the start. I do wear a chute when doing aerobatics.
Is there a reference to what is acceptable? i.e where it should be located? The 7 tipper could use either a linkage or a cable if the location has to be specific. If the same style linkage is used (but extended downward) a handle could be located under the throttle/prop/mix locations.
Bill
RV-7
Lord Kelvin:
Old 11-18-2016, 03:57 PM
ronschreck's Avatar
ronschreck ronschreck is offline
IAC Official Cintest Rules:
2.2(j) If the canopy, or door for cabin-type aircraft, is hinged on the forward (leading) edge, it
must incorporate a quick-release mechanism to facilitate emergency egress.
Van's design is all you need. You may modify to relocate the handle as long as you can reach it while strapped in.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 11-18-2016, 05:25 PM
scsmith scsmith is offline
Originally Posted by Ron RV8 View Post
A fair bit of my flying is over water...
I installed pip pins in the forward canopy attach points of the -8, primarily to jettison the canopy should I have to ditch. My feeling is that the aircraft would most likely flip inverted at touchdown, and that the canopy would most likely not be openable inverted in water due to the pressure.
Hard to say whether the airplane will be controllable after jettison, if the canopy frame hits the fin, which it most likely will on an -8.
The ideal thing for ditching would be to be able to slide it half way back and lock it. I think it might have been Jon Thocker that experimented with sliding the canopy open in flight. He found the stock fuselage construction lacks support for the track between the bulkheads and the flex of the track makes it hard to slide the canopy. Adding a partial bulkhead in the right spot may be a huge help. Search for his posts in the archives.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 11-18-2016, 06:42 PM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Default Regs are regs
but you will never get an unmodified -6 tipper (likely true of a -7 but I'm not sure) open enough in flight to egress the plane or to jettison the canopy. Requires slotting the forward skin over the hinges in a manner not to plans, or slowing down to maybe 15 mph.
(... so I guess you could do it in a hammerhead if you timed things perfectly.)
Since parachuting from the plane is a necessary capability for flying in sanctioned acro events, it seems to me a plans-built tipper should be excluded from entering without a demonstrated ability to accomplish this (no matter where your yellow and black handle is located). And I'd love to see how it's done, so I could shed my canopy if facing a water ditching
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
Old 11-18-2016, 07:24 PM
ronschreck's Avatar
All true. James Clark and I were making plans to demonstrate (on the ground) how far one needed to lift the canopy before the hinges released when we were informed by the IAC that any -6/7 with Van's canopy release mechanism would satisfy the IAC. No one knows how the 6/7 canopy will jettison in an uncontrolled situation and that can also be said for other aerobatic airplanes.
Ron Schreck
IAC National Judge
VAF 2021 Donor
Old 11-18-2016, 07:41 PM
Mel's Avatar
Mel Mel is offline
Default Original design of the RV-6 canopy was truly jettisonable.
Oh, but this WAS in the original plans. Mine has been this way for almost 24 years. I hope to never need this option in the air, but if I do, I have it!
The slots are covered with white tape, and no one has ever noticed unless I point it out.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-18-2016, 07:52 PM
vlittle's Avatar
vlittle vlittle is offline
There is a video of an RV slider ditching in shallow water. The pilot slid the canopy back prior to touchdown, but the impact slammed it shut and he ended up inverted. He was rescued by people on the beach. Better to eject the canopy first, but it may take the tail with it.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 11-18-2016, 09:04 PM
It might not be good to try and release a tip-up without the slot in flight. It can not go straight back. With the glare shield at head level, it would seem safer if it pivoted on the back (at the upper latch) so the front lifts and goes away leaving my head intact. I don't know any of this for a fact, but I did sit and stare at that sharp edged glare shield on day.
Is there a release procedure- like release the pins - then release the latch, then release the belts?
Bill
RV-7
Lord Kelvin:
Old 11-18-2016, 11:06 PM
rmarshall234 rmarshall234 is offline
I wouldn't be too concerned about the canopy taking out the fin. That part of the structure is pretty stout and remember, when the canopy is jettisoned it is going the same speed as the fin. How much can it decelerate relative to the fin in that short distance? At worse, I think it would be a glancing blow.
Old 11-19-2016, 06:16 AM
Mel's Avatar
Mel Mel is offline
That canopy is like a light weight sail. Once it leaves the aircraft, it will "stop" forward motion almost immediately. The tail is secured to the airframe. It will NOT decelerate quickly. I would expect substantial damage.
