Old 11-16-2016, 10:11 PM
PilotjohnS PilotjohnS is offline
Default Antenna quantity and location help
Just curious what antennas i need for an IFR gps equiped RV9. For planning purposes i will be using a garmin g3x system without ADF.
So far i have 2 nav/com antennas, one in each wingtip and glide slope in the gear fairing.
What else do i need and where inside the plan can i put it?
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 5% in work
Firewall Forward 5% in work
www.pilotjohnsrv9.blogspot.com
Old 11-16-2016, 10:47 PM
Need some clarification here. There are nav antennas and com ones, but since they require different polarizations there are not 'nav/com' antennas.
A wingtip nav antenna ('Archer' is one brand name) works okay for Localizer and VOR signals, although not as good as a pair of tail mounted cat whiskers. They are sensitive to installation details. The com versions of wingtip antennas only work fair to poor; it's hard to get enough of the vertical polarization that's required, inside the wingtip.
For glide slope you can always use your VOR antenna with a splitter. Some nav radios (like the SL-30) have an internal splitter, and no way of inputting an external GS antenna.
So you need to decide on specific radios before finalizing antennas. But for best results they should be external, with the possible exception of the wingtip nav.
Old 11-17-2016, 02:11 AM
rdamazio's Avatar
rdamazio rdamazio is offline
Aren't you forgetting GPS antennas? Transponder and ADS-B antennas? ELT antenna? Do you want to have a marker beacon receiver? Do you want to receive XM weather/radio?
No advantage in having two NAV antennas - you can feed a single antenna to multiple receivers. You still need two COM antennas since those are used to transmit.
Also with a G3X alone you can't be IFR certified, you need an IFR navigation receiver (such as the GTN750), which likely also adds at least one more GPS antenna.
I made a post when I decided my antennas, hope this helps:
http://www.airplane.build/2015/11/re...-antennas.html
(I have already changed it slightly since I posted - for instance, now I can use the GTX345R which does both ADS-B and transponder with the same antenna).
Rodrigo Damazio Bovendorp
San Jose, CA
RV-10 builder #41623
Build log at http://www.airplane.build/
VAF dues paid
Old 11-17-2016, 08:26 AM
Default Thanks for the post
Rodridgo,
Thank you for your post. This is what I was looking for..
I had a passing thought I could stuff all the antennas out of the breeze, but guess that was just a dream.
John S
RV9A- Status:
Tail 98% done
Wings 98% done
Old 11-17-2016, 08:49 AM
John Tierney John Tierney is offline
Default Antenna Location
Here is an antenna planning image courtesy of SteinAir
http://www.steinair.com/wp-content/u...ent-RV-7_9.pdf
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 11-17-2016, 10:52 AM
dave4754's Avatar
dave4754 dave4754 is offline
Default Comant - Comdat 200
I recently purchased a Comant - Comdat 200 antennae that says it will suffice for both GPS and VHF com.
I am building an RV 7 and plan on putting this behind the baggage compartment on top where the doubler already exists from VANS.
My question is do any of you have this antennae and was it good for you?
I know many like to use bent whip underneath but i fear loosing it on rough grass strips where i will fly.
I am using RG 58 coax and wonder what you have used and why RG 400 would be any different?
Dave C.
Dave Cobb
[color="Red"]=VAF=2019 Donation - and a bit extra for great work![/COLOR="blue"]
Empennage RV 7 - Tipper
Wings complete
Dynon installed and running
Fuse closer to completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 11-17-2016, 11:32 AM
Raymo's Avatar
Raymo Raymo is offline
Dave C.
Dave,
Lots of tail draggers have the bent whip antenna on the bottom of the fuse but it would be under the pilot seat area where ground clearance is sufficient.
RG400 is far superior to 58. The former has dual shielding while the latter is single.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 11-17-2016, 12:15 PM
Bavafa Bavafa is offline
Not sure if you need to Nav antenna specially that GPS will be the primary method for navigation. In addition to your list, I have a marker beacon antenna but hardly ever use it. I am also using my Nav antenna for my glide slop by the way of a slitter.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 11-17-2016, 01:13 PM
dave4754's Avatar
Default Thanks Ramo
I better get some RG 400
Dave Cobb
Wings complete
Old 11-17-2016, 02:04 PM
It's not that much more money, in the total cost. RG58 will work okay for the com, but at GPS frequencies, not so well. If you have a certified (TSO) gps I doubt the TSO even allows you to use RG58 (coax is much more critical at a GHz).
