Wear & tear would be the primary concern if on top of the floorboard; keeping it from rubbing and keeping feet/baggage/etc off it.
I might worry just a bit about PVC because its melting point is pretty low, but IIRC PVC was the go-to insulation for certified wire back in the 'good old days'.
Welding cable from your local welding supply (or ebay) is hard to beat for high amp cable. It's reasonably priced, very flexible, and insulation is super tough. Wire gauge should be selected to be big enough to handle any current the battery can deliver, so insulation should never overtemp from current load. If you have a fire big enough to burn the insulation...well, it's all toxic, anyway. If you have a well stocked welding supply, or look online, there are multiple choices for insulation. But I just used what was available.
EDIT: The one downside to welding cable is that the insulation is typically thicker than aviation grade stuff. Still a lot more flexible, but just takes more space to run it.
Beautiful build, BTW.
Charlie
