Old 11-13-2016, 04:30 PM
Dorfie Dorfie is offline
Default RG400 coax close to #2 AWG Batt cable
How bad is it to run the RG400 in close proximity (<2") or directly along the AWG2 batt. cable? VHF com antenna, GPS antennas. Will it be a problem drilling an extra hole in the F-1004C and D center section bulkheads? I am running out of space on the sides using the pre-drilled holes.
This is in RV10.
Thanks.
Johan
Dorfie
RV10 Flying, N245JM
2020 dues paid with a smile
Old 11-13-2016, 05:37 PM
flightlogic's Avatar
I personally would not worry about it. Main DC buss should be quiet.
The coax is good quality and radiates very little if at all.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 11-13-2016, 05:49 PM
snopercod's Avatar
Default It shouldn't matter
In theory, the electric field in a coax is contained between the center conductor and shield so it shouldn't matter.
(2020 dues paid)
Old 11-14-2016, 08:18 AM
Thanks guys.
Johan
Dorfie
RV10 Flying, N245JM
