Old 11-13-2016, 04:13 PM
ShortSnorter ShortSnorter is offline
Default Minimum Edge Distance
While finishing up section 16, I managed to smear one the last 1/8" rivet. I decided to drill it out and replace it, which went as planned. Driving the second rivet, I clinched the tail and now HAD drill out the rivet again.
As the story goes the hole became oblong in the W-1014 aileron hinge bracket assembly only and none of the other sandwhiched layers.
I then decided to upsize the hole to 5/32 to get rid of the oblong hole. Now, the problem is that I am 1/16" short on edge distance. Is 1/16" that critical or should I rebuild the hinge bracket assembly?
Ryan
RV-14 In-Progress
Build Site
Old 11-13-2016, 04:17 PM
60av8tor 60av8tor is offline
Merely my opinion, but edge distance is edge distance. Easier to correct now or once complete and you find a crack in the bracket?
Jon
Old 11-13-2016, 04:18 PM
wirejock's Avatar
wirejock wirejock is offline
Default Edge distance
I wouldn't even ask. That's a critical part and probably not very expensive.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 11-13-2016, 04:40 PM
After second thought, even if I rebuilt the hinge bracket, the bottom hole on the bracket would require 5/32" sizing since the underlying double and rear spar are already drilled to 5/32". I guess I shouldn't have been so drill happy
Ryan
RV-14 In-Progress
Build Site
Old 11-14-2016, 08:16 AM
JonJay's Avatar
JonJay JonJay is offline
2x dia. is a rule of thumb. Check the mil specs. You get a little more tolerance than 2x, but it may not solve this issue. If it doesn't, call Van's.
https://www.vansaircraft.com/public/Specs.htm
You are allowed .281 edge margin for non flush rivets, which is a lot closer than .3125 (5/16). I assume these are non flush rivets that go here?
Measure with calipers. You might have what you need.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-14-2016, 04:10 PM
Marc Bourget Marc Bourget is offline
Are you measuring the distance from the edge of the material to the closest edge of the rivet hole - or from the edge to the center of the rivet?
Check your edge distance rules. Mil STD-403C defines Edge distance as measured from the centerline of the rivet to the edge of the sheet or joint.
For a 5/32 rivet you would need .3125 from the edge. If you have .250 from edge of sheet to edge of hole, your centerline measurement would give an edge distance of .328125"
FWIW
Old 11-14-2016, 04:34 PM
I consulted with the mother ship today and came to the following conclusions:
-Since the aileron hinge brackets come pre drilled with exactly 1/4" edge distance, there would never be enough room to upsize the hole.
-Three options exist:
1) Replace the part along with the entire rear spar
2) Take the bracket off and cut the inner flange off and attempt to replace it with angle.
3) Set the single 5/32" rivet and check periodically after being service
In case anyone was wondering, I am going to opt for option 3.
I did however, order the inboard hinge bracket SB parts, so at least I'll get to drill some rivets out. One thing I learned was that the SB is not required on the outboard brackets due to the way they are mounted (spar and side of the end rib) and there haven't been any reports of issues on the outboard side.
Ryan
RV-14 In-Progress
Build Site
