Dimensions? Ha ha ha ha.... This is the canopy you are talking about. There are no dimensions for any of this work!
It is all finesse. Make it fit. Turn around and it will change on you every time you move it.
You can see all of the sharpie marks on my ears.
The good news is that by using the Sika Flex there is some fudge factor. Just make sure there are no pressure points where aluminum is up against the canopy plexiglass. You can see in the above picture where more trimming is needed (the curve marked in black). It is all going to get covered by fiberglass, so you'll never see it later on.
