11-19-2016, 08:01 PM
According to information I have found the equipment does not need to have an actual TSO, it needs only needs to meet the standard required for the TSO.
Jim
RV-6
RV-10 tail kit 50%
(When do I get to measure something?)
"Flying north of the Arctic Circle and back - several thousand dollars,
Doing it in an RV you built yourself - PRICELESS!"
11-19-2016, 08:05 PM
Originally Posted by az_gila
Errr... I don't think the 35R is actually TSO'd.
It meets the TSO specs but is for Experimental aircraft only -
As a remote-mounted transponder, GTX 35R makes installation easy, saves you valuable panel space in your experimental or light sport aircraft and integrates seamlessly into your flight deck. Manage squawk code entry and transponder control with only a few touches of your G3X series flight display.
Easy enough to check. When you sign up for the rebate you have to choose what equipment you're installing from a pull down list. If it's on the list it is approved.
Actually both the 35R and 45R are fully TSO'd units.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
11-19-2016, 08:07 PM
Jim
That's the rule to install it in an EAB. But only TSO's equipment is approved to get a rebate. I cannot explain the logic here.
11-19-2016, 08:15 PM
The 35R is in the list and the only thing I have left to do is wait for the rebate check to show up in my mailbox.
RV-6
RV-10 tail kit 50%
11-19-2016, 08:28 PM
Good to hear... their web site does not mention TSO in the press release -
http://newsroom.garmin.com/press-rel...-experimental-
And the data sheet just uses the word "compliant"...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
