Originally Posted by mike newall
They don't differentiate between the carburetted engine and the parallel valve injected and angle valve injected engine. If it says fuel injected on the plans, they mean the angle valve engine - not the parallel valve.
Uhoh, I just drilled three big eyeball holes for the cables on my TMX IO-360, using the fuel injected hole locations shown on the plans. Does your engine have vertical or horizontal induction? Mine is an IO-360-M1B (horizontal draft, parallel valve) so I was hoping that the cable locations for the IO-360-A1B (horizontal draft, angle valve) would work for me too. Here's hoping I don't have to patch over three big holes... yuck!
mcb
