Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 11-08-2016, 12:48 PM
Dean Pichon Dean Pichon is offline
Default PMag removal question
As part of the Annual Condition Inspection, I plan to remove the PMags from my -4 to inspect the bearings and cotter pins. Is in necessary or recommended to replace the magneto gaskets every time I pull a mag?
Thanks in advance!
Dean Pichon
Bolton, MA
Old 11-08-2016, 12:56 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Thanks in advance!
Dean Pichon
Bolton, MA
I say yes. They are inexpensive. I'm no A/P but I was always taught that most gaskets are a one time use item.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 11-08-2016, 02:19 PM
N941WR's Avatar
N941WR N941WR is offline
As Carlos said, "yes".
Besides, you will probably damage them when you pull the P-mag.
I smear mine with fuel lube when I install them. While it might help prevent leaks, it definitely helps hold the gasket in place when you put the P-mag back in.
One other thing, if your P-mag has not been returned for the Version 40 upgrade, send it back. I can't stress this enough!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
