Old 11-05-2016, 04:28 PM
RYOUNG RYOUNG is offline
Thanks, Dave. This should work:
http://i68.tinypic.com/f4fuki.jpg
Old 11-05-2016, 04:38 PM
Default Photo
Very good looking airplane!
Dave
Old 11-05-2016, 04:40 PM
Thanks for you help.
Robert
Old 11-05-2016, 06:18 PM
steve lenne steve lenne is offline
Default First flight rv3
Congratulations Robert
What motor prop combination have you got. How did your empty weight go? It took me six years and eight months to build mine which was completed in June And I am so pleased to own such a great aircraft.
Steve Lenne
Streak shadow (sold)
Jabiru 55,3j
Rv3
Old 11-05-2016, 06:46 PM
Thanks, Steve. I have an O-320h2ad lycoming 160 hp 0 SMOH. That alone probably added 6 months to the build due to mag firewall interference, non-standard baffling, fuel line routing, different engine mount, mods to upper cowl, etc. However it is really running well with plenty of power. Prop is a 2-bladed Catto. Empty weight is 810 pounds and c.g. is right in the middle of the envelope. Manual trim, no lights (day VFR only), manual flaps, GRT Sport EFIS, and EIS, backup airspeed and altimeter, Becker VHF and transponder. Painted with PPG Delfleet Essential single stage polyurethane black and white with vinyl letters/numbers/insignia. All-in-all I couldn't be happier with the outcome.
Robert
Old 11-05-2016, 07:29 PM
Robert
That all sounds very familiar except I fitted an io320 superior from aerosport with a two blade GA whirlwind prop. The rv3 is a test for anybody to build but fitting a non standard engine just adds to your achievement; well done .
My first flight was even more exciting as I had the prop set at 21 degrees pitch and left the ground at 3000 ft/min and when I levelled out the engine revs sailed past 2700. I don't really know the climb rate as that was the max on page I was using on the AFSeffis. I have no analogue instruments. My c of g is right in the middle and my honest empty weight is 827 lbs. manual everything, tail strobe and led landing light in the wing.
Steve Lenne
