Old 11-02-2016, 10:58 PM
simatos simatos is offline
Default Andair Fuel Valve
I have the Andair fuel valve. First attempt to run fuel through it and it leaked at both inlets. Sort of surprised so pulled it out to check tightness of allen head screws which secure the inlets. nest the allen key in nice and tight, snug up a bit and the head strips---rounds out and key is now turning. OK remove it since the valve comes with a few spares. Same thing happens with next 2 screws. Not really very tight and key turns in the head. Check the allen key, nice and sharp, no damage. Abit cheesed off, anyone run into this????
Old 11-03-2016, 02:32 AM
Bevan Bevan is offline
Hi Gary,
Yes I have run into this problem trying to solve a leak. Some screws I was able to get out by hammering a torx screw driver into the damaged screw. This only worked a few times until the torx bit was damaged causing more damage to the screw.
The remaining screws were removed with a more drastic approach. I carefully made slots in the screws with a very small dremel tool in order to get a slotted screwdriver on them.
After the ports were removed, I lubed the O-rings with grease then reinstalled the ports with torx head screws (available from Andair).
So far, no more leaks.
BTW, the O-rings and the allen/torx screws are metric. I was not able to find them locally.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 11-03-2016, 02:05 PM
wirejock's Avatar
wirejock wirejock is offline
Default Andair ports
Originally Posted by Bevan View Post
Hi Gary,
Bevan
Got my ports out and lubed.
Anyone have a photo of the valve mounted in the F-983A plate?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 11-03-2016, 03:17 PM
Raymo's Avatar
Raymo Raymo is offline
Larry,
Does this help?
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 11-03-2016, 05:50 PM
wirejock's Avatar
Default Fuel valve
Originally Posted by Raymo View Post
Larry,
Does this help?
Yes. I ended up fabricating a new plate. The Vans plate ends up with a hole edge distance violation with the forward most hole in the Andair plate.
Larry Larson
Estes Park, CO
Disclaimer
Old 11-03-2016, 08:55 PM
Thanks guys,
Ray I have the same octopus under my panel. I managed to back out the screws but I will need to put a slot in them as suggested to use again. Any recommendation what type of grease for the "O" rings? Thanks Guys, Cheers Gary
Old 11-04-2016, 10:38 AM
Rays panel looks alot neater now
Tom
Ridgeland, SC
Old 11-04-2016, 11:27 AM
Andrew Anunson Andrew Anunson is offline
My Andair valve came with two different allen wrenches. One of them is for the red handle, the other one fits the screws at the fittings.
Are you certain that you are using the correct size allen wrench?
Old 11-04-2016, 01:22 PM
rapid_ascent rapid_ascent is offline
I still have a brand new valve that I've yet to mount. I'm wondering what I should use to lube the O-rings. I think I'm going to need to rotate in fittings 90 degrees if I remember correctly. That might be a good time to lube the O-rings or should they come from Andair that way?
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 11-04-2016, 04:15 PM
RV7A Flyer's Avatar
http://www.aircraftspruce.com/catalo...ezturnlube.php
