Old 10-30-2016, 04:33 PM
sblack sblack is offline
Default Need workaround for skybolt fasteners
I don't have the tool to compress the studs so that they can be inserted in the grommets. I was planning to make one from vice grips but somebody borrowed my tig welder. Anybody have a MacGuiver type trick to install the grommets without that tool?
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 10-30-2016, 04:34 PM
Bruce's Avatar
Bruce Bruce is offline
Cleo pliers in a pinch
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
Old 10-30-2016, 05:06 PM
If you only need it for a week or two, I will mail you mine to borrow. Email me if you want it.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 10-30-2016, 06:13 PM
Bruce that worked. Knew the solution was right under my nose. Thank you. Rockwwod thanks anyway I'm all set.
Scott Black
VAF dues 2020
