01-15-2007, 01:06 PM
Originally Posted by f1rocket
It turns out that most of the stuff I want to protect with an Avionics Master are also on my Essential Bus!! That means that if my Avionics switch fails, by Essential Bus switch will turn them on.
Exactly my plan too
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
01-15-2007, 01:32 PM
Baa Humm bug
Avionics switch a good idea. 15 amps! wow that is a panel. Rocker switches have more capacity. You may need a relay. I bought two 40 amp solid state relay's on eBay for cheap $15 each. They cost about $50-$60 normally. Sorry I'm going to use them.
As far as redundancy, DPST, two switches, Essential Buss backup..... really on a VFR single engine plane?
Well I guess with glass cockpits, which mine is, even a VFR plane with a dynon, GRT eis4000, gps does rely heavily on electricity. Back in the day..... GA planes had mechanical and VAC engine and flight instruments, so electrical redundancy was not as critical. Times have changed in just the last 10-15 years. No one had a PC 20 years ago. Now if you don't have a cable modem you are in cave technologically.
I have yet talk to any one who has had an avionics switch fail or who's day was saved by an essential buss.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
01-15-2007, 01:40 PM
Well I guess with glass cockpits, which mine is, even a VFR plane with a dynon, GRT eis4000, gps does relay heavily on electricity. Back in the day..... GA planes had mechanical and VAC engine and flight instruments, so electrical redundancy was not as critical. Times have changed in just the last 10-15 years. No one had a PC 20 years ago. Now if you don't have a cable modem you are in cave technologically.
Yep, Been flying since 1967 and the only switch I've had fail was the landing light breaker/switch on a Mooney. Switch still worked, it would just get warm and click off. BTW, the reason I used the DPDT switch for my AV mstr..that's what I had!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
01-15-2007, 03:45 PM
That pretty much sums it up, George. I'm not sure I'll have any backup gauges at all in my plane. If I set it up for IFR, I'll probably have analog Airspeed, Altimeter and T&B. If not, you won't see one steam gauge. On the other hand, it makes the avionics a little more critical. Even for day VFR, while I wouldn't consider loosing the entire panel anywhere near an emergency condition, what a PITA it would be if you had no radios, no altimeter to determine TPA, etc. The real weak links are the switch, CB and main contactor. For the price of a switch and some wiring, the realibility of the whole panel basically becomes the reliability of the battery (or more to the point, the installed individual avionics). An outright failure of properly installed and maintained batteries or wires is practically unheard of.
Anyhow, my favorite kind of flying is still a Champ with no electrics at all, or a Citabria with 1 radio and a starter. Total electrical failure in that is, at most, a ho hum moment.
John Coloccia
www.ballofshame.com
01-15-2007, 05:17 PM
I also used a avionics master switch for the same reasons that you want one.
It is a Mil Spec switch rated for the currrent.
NO problems with it in 1,976 flying hours. The switch cost around $15 10-years ago from Newark Electronics. Recently I paid $28 for a 3 position double pole switch that was the same spec number for an ignition upgrade.
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
01-15-2007, 10:22 PM
Nothing wrong with an avionics master
Buy quality. Buy MilSpec. Rate the switch properly and enjoy the convenience. IMHO, if your avionics bus doesn't power dual EVERYTHING then your can ignore the 'single point of failure' issue since any 'one' failure will bring on the pain.
There is no argument. If you put a switch in your avionics line you have a 'single point of failure'. But.. got your approach punched into that GNS480? Got TWO of em? On separate busses? What happens if THAT is the failure point?? Then consider MY 'total electrical failure' experience.
Over the CA central valley, night VFR in a brand new '78 R182 when *wink* the whole thing went dark. Fog in the Bay Area so we did the fly the runway-wag the wings-thing at Modesto, got a green, pumped down the gear and landed. No biggie. Next day, found out that the problem was that the primary wire to the master soleniod fell out of a bad crimp. One wire. Dark airplane. Go figure.
So.. Design your airplane with the intention that it will work. And it will, if you wire it right. When it doesn't, have a plan and backup.
My backup is an ICOM A22 and an old G196 plus a Sporty's/Castleberry ADI/bubble to keep me upright. That and knowing that I'll NEVER fly this thing out of reach of VFR should do it.
Short answer:
Build the airplane like you want it to work. Have a plan when it doesn't.
John
John Oldenkamp
RV-7A project for sale
VAF Paid 2018
01-16-2007, 09:23 AM
So George, if John's Cessa had had an Essential bus, all he would have had to do was flick the switch and continue on. I guess there's your "story" you are looking for. Not "necessary" as he got down okay without it, but that's what it's there for. I don't have any added complexity since I had to wire the devices up to a bus anyway, just doing this way gives me options. Plus, it backs up my avionics master switch.
No more complicated, just a different way of doing it.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
01-16-2007, 09:54 AM
Second Thoughts
I've experienced two switch failures (and one battery failure) in aircraft. The first was a battery master (the famous red split switch) failure, the second was an avionics master switch failure. Both occurred (at different times) in my '79 182. When I built my RV, the failure of the avionics master switch was fresh on my mind, so I didn't include one. I do have an endurance bus.
My point is, on retroflection, that the avionics master switch failed after 26 years of use. I must admit, I don't enjoy turning everything off manually. I'm not sure I made the right decision, but thought I'd add a data point for you. Either way, there is always that chance...
RV7A-QB, RV-10
01-16-2007, 04:44 PM
Agree with first, only somewhat agree with the second, but is true ONLY when the pilot is intimately familiar with the electrical system and can quickly determine which devices to power off or breakers to pull to "shed the load."
I envision the the the intent of the E (endurance or essential) Buss is to automatically isolates all of the critical devices so if there is a failure, they will continue to operate regardless of the on/off state of the other devices NOT on the E buss. For example if you have an alternator failure and you don't remember to turn of the landing light, it won't drain your E buss battery. These are obvious examples but there could be many devices consuming battery power during an alternator failure, that a pilot may not be aware of.
In my system, I will have a main buss, an E buss, a main avionics and a E avionics buss. I will have a main battery and an E buss battery. Initially I will have only one alternator that will charge both buss but it will be "one way" -power can flow from main to E, but not from E to main. Later I will add a second alternator on the E buss. In "all electric" airplanes, an E buss cuts the workload in an emergency.
01-17-2007, 04:56 PM
Gary Bricker
I have a spam can Beach that has two separate switches in parallel on the ground side of the Avonics. These were installed by a Avonics shop years ago when I bought it. I don't know if this is good or bad.
