Old 10-29-2016, 10:04 PM
Xkuzme1's Avatar
Xkuzme1 Xkuzme1 is offline
Default Matching paint codes. Please help.
i have been unable to match my white color code. I can't find any reference to the number. Does anyone have any ideas? This picture is taken from the logbook.https://drive.google.com/open?id=0B7...0RnQnVrZGlrcVE
RV-4 - 0-320 (160HP)
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 10-30-2016, 01:17 AM
greghughespdx's Avatar
If all else fails, take a sample to your local paint shop (access panel cover plate or something like that) and they can color match it.
Building RV-8A since Sept 2014 (N88VX reserved)
Aurora, OR (EAA Chapter 105)
Old 10-30-2016, 09:13 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Check with your DuPont (or Axalta) dealer. They did change a lot of the color codes sometime in the past, but should have a cross-reference (or mixing formula) to their present paint types.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-30-2016, 12:05 PM
SST110 SST110 is offline
Default Dupont
8796 is an old code for a shade of white Dupont Imron paint. I believe it was from their marine color charts and I think it has a very slight blue tint to it. Any large Dupont paint distributor should be able to track it down for you. If I knew how to post images I could post a color chart I found online showing it. Here is a link that should show the chart.
http://www.rideyourbike.com/images/paint/paint3.jpg
Paul
Old 10-30-2016, 12:13 PM
Xkuzme1's Avatar
Nailed it. It is very white... with a slight blue hint. Very tough to match this white so far.
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 10-30-2016, 03:21 PM
Jesse's Avatar
Jesse Jesse is offline
I would recommend a color match from a local paint supply store. Any fade would make the new paint of the original color not match. I have had great results having the paint store match colors.
Jesse Saint
