10-27-2016, 06:33 PM
Cold Cylinder on New Engine
So, I and a buddy are at the airport this afternoon and decide to conduct a taxi test. At start up, everything is smooth as butter, but toward the end, my #4 cylinder basically went off line...very low CHT and EGT. We ran the engine up to 1800 and were able to get the CHT/EGT on #4 to come up, but as soon as we reduced throttle, it went away. I'm thinking clogged injector.
What say the experts?
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
10-27-2016, 06:58 PM
As this is a first run problem I recommend you look for less traditional causes. For example, the symptoms you discribe could be explained by the engine sucking in a bolt that gets suck under the intake valve holding it open. Look also to a loose intake pipe on #4 that is letting in air.
If you have a borescope you might want to look into #4 and its valve seats.
Injectors are easy to clean so do that. As I've seen this exact problem from a tiny piece of crud in the spider keep that on the list.
Good luck,
Carl
10-27-2016, 07:01 PM
I forgot to add - to check for a clogged spider do the shot glass test. Do the flow test at idle and at power. If #4 has less flow you have your smoking gun.
Carl
10-27-2016, 07:06 PM
That was part of the plan for tomorrow. Got the AFP manual open right now looking at that procedure. I'll do the easy stuff first and go to the harder stuff progressively. It wasn't a "first run" issue per se as it has been run probably 6-8 times for different reasons. I did a full power run up the other day to check static rpm (~2150, which Catto says is the target for the prop I have) and #4 was the hottest cylinder. Something happened in our taxi test this evening to change that.
www.marksrv8.com
10-27-2016, 07:28 PM
I had a dead cyl at idle. Was hard to see but micro piece of something yellow in the fuel divider.
For reference the slot is ~0.003"
Weasel
RV-4 715hr Sold
RV-10 "School Bus" -   +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
10-27-2016, 08:36 PM
I am with weasel. Your symptoms point to a problem condition only at idle and intermittent. Flow divider is high on the list for that symptom, especially with newly installed fuel delivery components (a great source for debris)
Larry
10-27-2016, 08:53 PM
Maybe something even more basic... Check that the CHT and EGT probes are properly connected to that cylinder.
Rob Prior
10-27-2016, 10:20 PM
Good advice so far, but I'd add a quick test: pull the prop thru 2 revolutions and make sure you're getting a good "squeeze" or compression out of all 4 and you don't have a dead hole from FOD in the engine or worse.
If any doubt do a leak down test.
Tim Andres
10-28-2016, 04:45 AM
All great advice and will do today! I'll report back!
www.marksrv8.com
10-28-2016, 02:24 PM
Turned out to be some crud in the injector nozzle. I pulled the #4 injector and cleaned it with some acetone. There were two tiny bit of crud. One looked like it could be a tiny bit of sealant and the other was a tiny black fiber of some sort. Anyway, I put all back together and ran it up. All cylinders normal now. Thanks again for the advice! I'm very relieved it was a simple solution.
www.marksrv8.com
