I recently had the same problem, engine leaned out at 2000 RPM on the ground and didn?t accept full power. Fuel pressure and fuel flow went down. I tracked the problem down to the (duplex) boost pump and learned that this pump was not the right one.
Which pump do you have ??
RV-7 flying, IO-375 w. P-Mags, 200RV Prop
RV-8 flying, IO-375, P-Mags, 74RV Prop
