Go Back   VAF Forums > Main > Reviews
Old 10-25-2016, 01:56 PM
SJordan SJordan is offline
Default Amazing customer service from Raven Aircraft.
Have to put a big thanks out there to Rob over at Raven Aircraft. I purchased a used second hand Raven inverted oil system and had a small problem with the oil tank, most likely not Ravens fault. Gave Rob a call and he immediate offered to send out some replacement parts at no charge. If anyone is looking for inverted oil or just a good oil separator system go with the Raven, there products are top notch and boy do they stand behind them. I will be definitely looking into there Raptor sump when I build my engine.
[/url]
