sub-panel attach
If you're looking at dwg 24a, for the tip up, the dwg for the top angle (F-703B) that goes around the top of the instrument panel, the dwg is full scale, so measure it, but remember it is marked on the left of the dwg as "symetrical about centerline," meaning, the dwg is only 1/2 of total lenght...you can do the same for the cutouts. That is if I'm reading your question correctly...I'm looking at slider dwg now if they are different..
Good luck
Ron 9A
Finish/FWF
