Old 10-24-2016, 12:22 PM
flyboy1963's Avatar
Default swapping Bendix for Slick mags, will the gear fit?
So planning to remove an older Bendix, and install a Slick 4250.....can I use the same gear? 0-320-A
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 10-25-2016, 10:21 AM
jrs14855 jrs14855 is offline
Default Gears
A quick search says the gears are different for Bendix and Slick.
Old 10-25-2016, 10:56 AM
rv7charlie rv7charlie is offline
Cheaper to rebuild the Bendix....
Old 10-25-2016, 11:30 AM
RV6_flyer's Avatar
The Lycoming Parts manual shows 3 different gears were used depending on if Impulse, regular mag, and retard breaker mag were used.
When I changed my old S4LN-20 and S4LN-21 mags for LASAR ignition, I was able to use the same gears. LASAR mags are slick mags with some special parts.
I can find no reference for different gears in my Lycoming PC-103 parts manual. The manual shows Slick mags on the E2D using the same gears as the Bendix mags that were on the B2B.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 10-26-2016, 10:38 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Keep the Bendix
Unless the Bendix is DOA, you would do better to overhaul or exchange your Bendix.
(I believe most experienced IAs/A&Ps would agree)
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
