Old 01-14-2007, 02:35 PM
Tony Spicer Tony Spicer is offline
Default Cowl fastener question
Disregarding the additional time it would take to remove the fasteners, what's the downside of just using 8-32 anchor nuts, SS Torx screws, and flush finish washers to attach the cowl ? Intent is to use them just across the top of the cowl and inboard sides of the intakes, with hinges per the plans everywhere else.
thanks,
Tony, RV-3B 11395
Old 01-14-2007, 02:44 PM
Mel's Avatar
Mel Mel is offline
This configuration has been working great on my -6 for almost 14 years. However, you want to use the screws across the bottom too. The hinge "eyes" will not hold up to the pressure and vibration. Hinges work fine on the vertical and horizontal sides.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-14-2007, 02:58 PM
What Mel said.
I have 10 #6 stainless steel screws across the top of the cowl on my -6, and 8 #6 and 2 #8 screws along the bottom of the cowl.
I have the hinges running vertically on the cowl sides and horizontally along the cowl split line.
No problems over 6 years and just under 450 hours.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-14-2007, 03:29 PM
Thanks for the input, guys. The -3 doesn't have any fasteners across the bottom of the cowl, so no problem there.
Tony
Old 01-18-2007, 09:52 PM
mike newall's Avatar
mike newall mike newall is offline
If you are using countersunk screws consider this.
We refurbished a Christen Eagle before the RV project and the cowls were shot - lots of rebuild needed due to the screws damaging the fiberglass. When we re drilled the holes, we countersunk them and epoxied Tinnerman washers in the hole and glassed over with deck cloth. When set, just touch with a countersink to clear the cloth and you end up with a stainless receptacle for the screw that distributes the load into the cowl - will last for years and didn't take long to do.
