Old 10-24-2016, 08:45 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Default Leading edge re-skin
I'm pretty certain I know this answer, but was wondering if anyone knows a trick I don't and can save me time.
The back of the wing leading edge rivets to an aft-facing flang under the aft skin. Can I replace the leading edge using solid rivets without pealing back a corner of the bottom aft skin?
Thanks!
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Old 10-24-2016, 08:59 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Which RV?
Carl
Old 10-24-2016, 09:17 AM
BruceMe's Avatar
Default RV-6
I'm talking about an RV-6
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 10-24-2016, 09:22 AM
BruceMe's Avatar
Default Tip, lightning holes and inspection access?
I'm looking at pictures and thinking... Maybe I can get to that flang through the tip, spar lightning holes and most crucially the inspection panel.
Does that work?
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 10-24-2016, 10:23 AM
Does that work?
I suspect it will. A long arm helper who has done a wing or two would be a big help.
Carl
