Old 10-23-2016, 07:54 AM
Driving '67 Driving '67 is offline
Default Interior Paint ideas - Pics request
Hi All,
I'm getting to the point of painting the interior on my 14. Funny I find making decisions about the avionics/mechanical options easy but colour choices are a bit more challenging.
I'm leaning towards SW Jetflex Gray WR (paint code 7802). I'd appreciate if I could ask the VAF gang if they could post a pic or two of any gray toned interior prior installation to any type "Classic Aero" panels. Anything that catches a panel shot would be great.
Thanks Jim
RV 14A
Serial 140118
Donation - 2020 gladly done!
Old 10-23-2016, 08:08 AM
rv6builder's Avatar
rv6builder rv6builder is offline
Default Stewart Systems battleship grey
I used stewart systems Battleship Grey. Fantastic paint to work with, cured up really durable and easy to spray and clean up.
Alex
Alex Doughty
Canadian ATPL
Flying!!
Old 10-23-2016, 08:41 AM
cderk's Avatar
cderk cderk is offline
Alex - did you use Stewart Systems primer underneath or did you just etch and paint? I've been using the Eko Prime and am pretty happy with it. I'm not sure how durable just the primer is though.
Charlie
RV10
http://n688cd.wordpress.com
Old 10-23-2016, 09:04 AM
rv6builder's Avatar
Default Primer
I did use the eko-prime primer on all the bare metal surfaces. I used the eko-poly over the primer on the interior. I would not reccomend applying top coat directly to etched bare metal. I did find the primer durable, and adhered great but as with any flat finish primer, it shows dirt and fingerprints that are tough to get off.
The big thing I found with Stewart is follow the instructions to the T, and make sure every last little edge and corner has had the apropriate prep work done and the top coat will go on great.
Alex
Alex Doughty
Canadian ATPL
Flying!!
Old 10-23-2016, 09:08 AM
wirejock's Avatar
wirejock wirejock is offline
Default Jet Flex
Here's mine. Panel is not done yet.
Jet Flex Solvent Based Basic Grey flat (BAC704) and Black flat (BAC706)
Painted before riveting so rivets and screws would contrast.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 10-23-2016, 09:51 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Color Match
JetFlex water based paint is great stuff, but don't worry about colors.
Alliance Coatings did a great job mixing paint to match a color chip I sent them, all for a small fee.
Pick the color you like, from an auto interior or from Home Depot color chips, and make the paint the color you want, not some stock color.
http://www.alliancecoatings.com/
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-23-2016, 04:46 PM
mike newall's Avatar
mike newall mike newall is offline
As Gil said, keep looking around and start checking colours out. I have used filing cabinet grey and Airbus toilet interior grey previously. Just get a sample colour matched and away you go.
Make sure that the mix for both the interior and exterior are written down inside the cover of the logbook as soon as you decide, otherwise you will forget and need to mix some up later.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 10-23-2016, 08:50 PM
rapid_ascent rapid_ascent is offline
I went with the Jetflex WR Pepperdust color. Get a color chart. Mine is amazingly close to the paint chip on the chart. I've just started spraying the individual pieces.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 10-23-2016, 09:18 PM
lr172 lr172 is offline
I used the SPI epoxy primer. It is tough as nails and inexpensive. It also reduces weight by avoiding both a primer and top coat. It only comes in one color though. However, I like the light gray.
Larry
