  #11
Old 11-01-2016, 11:09 AM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by Chkaharyer99 View Post
Bill,
What about the configuration for a Titan IO-360 with high compression pistons (9.1:1)? Is there a safe setting that can be achieved?
Typically, you want to move the spark closer to TDC when you go with high compression pistons. I would check with with your engine builder to see what their recommended timing is and then customize your P-mags' configuration to match. (Check your data plate, the recommended timing might be on there.)
You can configure the P-mags with either the EICAD program, which you can download from the Emag website or with an EIC. You do not need the EIC to configure your P-mags, but it does make it easier and you can monitor your P-mags with the EIC, which you cannot do with the EICAD program.
Let me know, if you have any other questions.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-01-2016, 01:34 PM
LuisR LuisR is offline
When will the 540 (6 cyl) version being released officially?
Regards
Luis
---------------------------RV-10---------------------------
Empennage. Complete Minus fiberglass and attach section. FOR SALE
Build Log N925LC (Reserved) YouTube
Old 11-01-2016, 02:44 PM
Auburntsts's Avatar
Around the same time as the Moller Skycar.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 11-01-2016, 02:46 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Good to hear the PMags are doing well!
Neal Howard
Airplaneless once again...
Old 11-01-2016, 03:25 PM
Chkaharyer99 Chkaharyer99 is offline
Thanks Bill!
And thank you JJ for the thread. I'm going to replace at least one of my Slick Mags with EI. Trying to make a more informed decision on which one.
Glad to hear you like your Emags.
Charlie
RV-8
