  #11
Old 10-20-2016, 09:45 AM
flyboy1963's Avatar
Default ah, rookie needs help here
.....so, you guys are all missing the BIG question......
WHY?
I tend to use the 'max lift' setting, about 15 degrees, when gusty or x-wind...but am not sure why.
the wing loading is the same I think....if you are approaching no-flap at 70 kts, yes, a gust will affect you a bit less, but eventually you will transition to 60, then flare, then touchdown at 50 or whatever, all times when a gust can upset you just the same.
I can see the TD guys might want the speed to make a firm wheel landing, but when is more lift a BAD thing, especially if you need to make a go-around?
.....inquiring minds want to hear from the experts!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 10-20-2016, 09:57 AM
rmartingt's Avatar
90% of my landings in the -6 are half flap, the other 10% full flap. I can't remember the last time I landed with no flaps. But then, in that airplane there's no flap motor to not work.
RV-7ER - finishing kit and systems installation
Old 10-20-2016, 10:10 AM
Saville's Avatar
Saville Saville is offline
WHY?
You have to figure out why you do that, or how your approach changes.
Do you do it so that you can approach with the same lift but at a lower speed?
Or do you do it to make a steeper approach at the same speed?
If the former, then the gusts will have a larger effect on you. If the latter then there should be no difference.
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 10-20-2016, 11:53 AM
PerfTech's Avatar
PerfTech PerfTech is offline
WHY?
...The reason why you don't use your flaps in gusty conditions is to help eliminate float, and increase touch down speed. This widens the safety margin for stall speed. Thanks, Allan..
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 10-20-2016, 12:09 PM
ArVeeNiner's Avatar
Unless I'm practicing no flap landings, I use full flaps every time I land. Why? Because Mike Seager told me to.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
Old 10-20-2016, 12:12 PM
Bevan Bevan is offline
Every landing is a flap landing unless the flaps are broken or training for flapless landings.
The use of flaps on an RV is no different than any other GA aircraft. If you're not sure why (and how much) flap to use on landing, maybe get with an instructor and go over some basics. Kinda hard to teach flying online but here's my take on landings...worth less that what you have paid for it....
-The ultimate goal of landing is to stop flying (safely).
-To stop flying, one must slow down and approach the ground.
-This requires more precise (maybe just different) flying skills than cruising.
-Crosswinds become more of a factor as your forward speed declines and you need to maintain track over the runway and aircraft generally aligned with direction of travel over said runway.
-The first amount of flap is to increase lift (enabling you to slow down even more), and adds some drag, and lowers the nose resulting in better visibility.
-Going to Full flap basically adds more drag which helps with speed control. In the slow speed regime, pitch now controls speed, and power now controls rate of descent.
-After touchdown, the flaps and the slower speed allows shorter roll, less energy (you want to stop afterall) with less (maybe no) use of brakes saving them for whenn you really need them.
-The above is for normal landings. Now, If you have crosswinds, it will be more challenging to control track and heading over the runway at touchdown. Reducing some flap, increases stall speed thereby reducung the crosswinds effect (a little) allowing better control but the trade off is more speed on runway, more brakes, longer (possibly much longer) stopping distance etc.
-Gusts are probably a more significant factor. Add 1/2 the gust factor to your approach speed and flaps (less than normal) to suit that higher stall speed.
Practice practice practice for consistency and variable conditions.
Bevan
Not a CFI but I...
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 10-20-2016, 12:14 PM
flyboy1963's Avatar
Default could this be another ....'debate'???? :)
hey, love the discussion Allan....
let's say I approach 'no flap' at 70, stall is 55, margin is thus 15.
If I approach at 70, half flap, stall is 50, margin is now 20, so I can tolerate more gust/shear without 'dropping' it in.
also would say more flap = less float, especially if you shave 5 kts off the approach speed, still have the margin, but on the ground sooner.
maybe.....
maybe not?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 10-20-2016, 12:19 PM
luddite42 luddite42 is offline
Disagree. Flaps up increases potential float because it lessens deceleration in ground effect due to reduced drag.
Old 10-20-2016, 12:39 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 10-20-2016, 12:40 PM
jfrank71 jfrank71 is offline
Default Flaps in the RV-10
I think it has a lot to do with the airplane. In the RV-10, solo or two up front, 0-20 degree flap landings make it much easier to keep the nose wheel off the ground. If I have four passengers and luggage, the I can use full flaps and still keep the nose up pretty easy. Wind plays a factor too. High winds usually mean less flaps and less float. My suggestions is practice multiple configurations in different conditions and see what works best for you and your RV. Main thing is to be safe and enjoy flying!
Frank Leone
RV-10 Purchased
RV-12 Under Construction by my kids, wife & me
Donated 8/2018
