Pitot retrofit plumbing
I read multiple threads about plumbing the pitot/AOA while building as well as threads about where to place the mast for a retrofit but, I don't see much detail about running the pitot/AOA lines in a retrofit. I'm replacing the standard bent tube Vans pitot with the Garmin unheated Pitot/AOA on my -9A. Got the Gretz mast and will locate in the bay just outboard of the inspection cover as suggested in multiple threads. My question regards the actual plumbing and eventual track into the cabin. Since there is only one line and there will need to be two, has anyone used the single as a fish line and pulled the two from the cabin out to the wing? The conduit for strobe and position lights seems pretty full so I don't see that as an option. Would removing the left fuel tank make this better and easier in the end? After removing the wing root fairing, there is very little improvement in access or visibility. All I can see it the pitot line entering the cabin just under the aileron push rod. Hints from anyone who has done this already would be welcome.
Thank you,
David
RV-9A N435KR, Vans calendar March 2018
LIO 320 B1A, Dual LS Plasma III, AFP injection
G3x touch
Roseville, Ca
