10-15-2016, 02:59 PM
Need help with tank leak
I have read many threads about proseal and sucking in loctite. I did not build the tanks but did test them for over six months full of gas with no leaks. I did attempt to get the tank off including assuring the bolts on the Z's were removed, No Joy. Apparently the skins are locked to the spare flange in the dimples beyond relief. I feel I would need to destroy the tank to remove it.
The leak appears to be in the rear bulkhead because the stains are along the tank skin parting line with the bottom wing skin. I assume that flight stress over 80 hours or thermal expansion stress has initiated this small effluent.
I know sloshing is not historically prudent. Any suggestions would be appreciated before I order a tank kit or new wings.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
10-15-2016, 03:46 PM
It will come off. They can be really hard to get off sometimes. Push up and down. We've even had to tap on the fill cap flange with a block of wood and a rubber mallet before.
Of course, double check that every single fastener is removed.
Jesse Saint
10-15-2016, 05:16 PM
You can *carefully* lift the skin & carefully wedge something thin, like popsicle sticks, under the top flange to release the dimples. Be sure to support the tank and/or have help, to prevent dropping the tank quicker than expected.
Charlie
10-15-2016, 09:11 PM
Use caution.....
There are 3 bolts for every rib in the tank. It is easy to accidentally miss some.
If you haven't removed that many bolts, you will damage the tank if you start using force to try and remove it.
Scott McDaniels
Hubbard, Oregon
10-16-2016, 01:37 AM
Plastic separator for tank removal
Even with all the screws removed, those dimples keep a fierce hold on the tank! Getting the tank off is MUCH easier if you put a piece of plastic between ALL the countersink / dimpled screw holes. I use cheap For Sale signs from Home Depot. They are just stiff enough to allow you to work them between the skins but thin enough that they don't bend anything. Us as many pieces (signs) as needed to get pieces of plastic between all the screw holes on the top and bottom. Then, once you have all the other mounting hardware loose, the tank will pull off easily.
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through March 2021
10-16-2016, 11:42 AM
Originally Posted by rvbuilder2002
There are 3 bolts for every rib in the tank. It is easy to accidentally miss some....
I believe that on an RV-3B there are only 2 bolts per Z-bracket. At least that's what drawing 7 says and that's what I put on mine.
Dave
RV-3B, now on the fuselage.
10-16-2016, 01:15 PM
Dave
Oops
There are not a lot of the new wing RV-3's.... and I didn't look at his signature so assumed it was a 7 or 8
Scott McDaniels
Hubbard, Oregon
10-16-2016, 01:43 PM
Oops
That's OK Scott, I for one appreciate the feedback you provide. Not to hijack this thread, but I may have ot pull the tanks on my QB -10. Does the 3 per rib hold true there too?
thanks
-Marc
RV-10
N814RV
2020 Donation Made
10-16-2016, 02:13 PM
thanks
-Marc
Yes, it does.
Scott McDaniels
Hubbard, Oregon
