I now buy Tempest aircraft plugs, fired by Magneto. I use auto plugs with the Pmag, they are Autolite 386 for the O-290, & NGK BR9ES for the O-360.
In a pinch, I don't mind mixing Champion, Autolite, Tempest, Auburn or other FAA approved spark plugs as long as they match the heat range of the others, and run well (EGT & CHT).
I also use Philips XC 20/50 oil, but don't mind adding a quart of Aeroshell or Exxon Elite if that's what is available at the FBO when traveling.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
