Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 10-14-2016, 04:24 PM
Dave_Anderson's Avatar
Dave_Anderson Dave_Anderson is offline
Default Opinions Please: LSE Plasma, using shield for ground
Hi Folks,
Looking for opinions and experiences here. I am about to install my dual LSE Plasma 3 setup and in studying the wiring diagram discovered that the shield portion of the power wires is used to provide the ground to the ignition system. Knowing that my soldering skills are probably less than that of Klaus and his team (my crank sensor came prewired and potted w/silicone and would ahve to be totally redone if I change), I am probably going to do what is recommended. I have never heard of doing this sort of thing and wanted to see if anyone has any experience with this setup (no issue, some issues, recommendations).
I appreciate your replies.
Dave
Old 10-14-2016, 04:59 PM
SMO's Avatar
SMO SMO is offline
Don't know anything about the LSE Plasma system, but the practice of using the shield on a shielded cable for a ground is not unusual.
I caution you on the method used to strip the outer sheath - DO NOT cut around the sheath but gently slice down the length of it and snip off the piece to be discarded with snippers. When cutting around the sheath it is very easy to cut a little too deep and put a minute cut into the insulation of the wires beneath. Then if a little strand of the shield gets into this minute cut you have a short that is very difficult to fine, and is potentially intermittent. Stein has a video on his site with respect to this.
Don't ask how I know!!
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 10-14-2016, 05:24 PM
rv7charlie rv7charlie is offline
Mark's right. Your radio coax does the same thing. Also TV coax, unbalanced microphone cables, guitar cords, etc.
Charlie
Old 10-14-2016, 11:31 PM
cbennet1 cbennet1 is offline
Originally Posted by Dave_Anderson View Post
Hi Folks,
Dave
Hi Dave,
The method described works fine on my LSE installation.
Craig
Craig Bennett
321GT Flying RV6
2018 dues paid, how about you?
Old 10-14-2016, 11:58 PM
Thanks folks.
Old 10-15-2016, 06:26 AM
N427EF N427EF is offline
Default Follow LSE instructions
When it comes to LSE ignition, follow the instruction precisely.
When installed as instructed, the LSE ignition works flawlessly.
Nearly 1000 hours on 2 RVs with Light speed ignition and zero issues.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 10-15-2016, 08:04 AM
sjhurlbut sjhurlbut is offline
Default Grounded shielding
I've installed Plasma III in almost all my airplanes and follow the wiring instructions. There is a technique to getting the shielding off however. Once the outer casing is removed carefully push the shielding downs so it looks like a sphere. I use a piece of safety wire to start opening a hole in the side of the shielding, then fish the centre wire through it. You should end up with equal length centre wire and shielding without having cut any of the shielding strands. Once you crimp on the connector so can heat shield to add strength. I also add a dab of Shoe-goo (or equivalent) to the base of the connection if I want it water proof or so added strength on areas of vibration (I do this on coli connections on engine side).
I've never had a Plasma issue in 4 airplanes and 1000s hours.
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - building
Old 10-19-2016, 01:53 PM
deek deek is offline
As others have said, read the installation manual carefully and follow Klaus' instructions to the letter. I've had LSE Plasma systems in 5 homebuilts with over 6,000 hours of trouble free flying (with the exception of the evil Hall Effect mag hole trigger).
Oh, did I mention following the instructions?
deek
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
