  #11
Old 10-14-2016, 03:42 PM
AX-O's Avatar
AX-O AX-O is offline
Originally Posted by SampsonSurgical View Post
Was your suction cup black?
Yes (extra words).
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 10-14-2016, 03:47 PM
Bevan Bevan is offline
Can you put the suction cup on the opposite side directly over the dimple, then add some heat with a heat gun from the inside to neutralize it?
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 10-14-2016, 06:08 PM
BillL BillL is offline
Bevan
Where is it? A casting of flox resin in a similar area could create a good "mold". then it could be attached with suction and the area heated. The drawback might be a nib at the point of suction. A nib could be polished out though.
Thanks for the warning! Good luck with any attempted repair.
Bill
RV-7
Lord Kelvin:
Old 10-14-2016, 10:07 PM
I had the suction cups themselves melt enough to curl up and become useless. They were on a radar detector mount in a black Infiniti Q45 (black interior too) in Tucson, with an ambient temp of 118 F. It probably got up to 160 in the car!!
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 10-15-2016, 10:23 PM
SHIPCHIEF SHIPCHIEF is offline
I vote that you do nothing and wait. I think that the dimples will eventually fade away.
Any proactive measure could go awry and cause permanent damage?
I saw your RV-4 at Reno. Very nice. The prop was very interesting too.
Congrats on the Rookie of the Year award!
My first year at Reno, this could be habit forming. I see that being a spectator has limits. It seems best to be associated with a plane.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 10-16-2016, 01:13 AM
skylor's Avatar
skylor skylor is offline
Default Comparison
Originally Posted by AX-O View Post
Yes (extra words).
Hey Axel,
Just as a point of comparison, I also had one of my GoPro cameras suction cupped to the side of my canopy for the entire Reno "week". I have the older GoPro mount with the clear/translucent suction cup. My canopy was mostly uncovered during the daytime and we only covered it up late in the afternoon every day. I took a good look at my canopy today, and I could detect no deformation where the mount had been located. I made sure to view it with good lighting casting a "glare" on the canopy and there is definitely no deformation. So either the black suction cup contributed to your issue or the RV-4 has a thinner canopy than the -8. Or both.
Hopefully with time and some temperature cycles, yours will relax back to the original shape.
Skylor
Old 10-16-2016, 09:02 AM
AX-O's Avatar
Thanks for checking. I dont have a vans canopy. Mine came from Todd. It is also the clear type. No tint.
Axel
Old 10-16-2016, 09:07 AM
I wonder if your problem was heat related or plasticizer related. Plasticizer is the component in soft rubbery plastics that keeps them soft. It can eat or soften other plastics if the two materials are in contact.
That's what used to happen with plastic fishing worms and tackle boxes before the tackle box manufacturers figured out the chemistry.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
