Old 10-13-2016, 12:01 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Default FltplanGo runway extension
HELP! I changed something on FltplanGo Android tablet and the runway centerline(s) no longer show up on the map pages when I do a flight plan. My Android phone shows them just fine and the settings are the same. I can't find anything in their FAQ or manual. Does anybody know what you need to do so they display again?
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 10-13-2016, 01:19 PM
Raymo's Avatar
Raymo Raymo is offline
I could not find the setting on my iPhone either but this is how it is supposed to be enabled.
EDIT: Found it. Enable the option to "Show runways on Map." It only shows extended lines at the airports on your route. Certainly could have been labeled better.
(source)
Extended Runway Centerline: With this new feature, all the runways for your arrival airport will have a 7 mile extension shown on the maps. This is a great visual aid for identifying the orientation of the available runways at your landing airport and your aircraft position. You can also change the color of the Runway extensions for better contrast on the map background you are using, or you can turn this feature off. The Extended Runway Centerline feature can be accessed from the Maps page, and using Map Option, then Runway Option section.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 10-13-2016, 01:34 PM
GalinHdz's Avatar
I tried that and still can't display the centerlines of the arrival airport. It was working fine until I messed with it and now can't remember what I did.
Galin
CP-ASEL-AMEL-IR
2020 Donation made
Old 10-13-2016, 04:01 PM
tomkk's Avatar
tomkk tomkk is offline
On the Map display, tap the Gear icon at the top. Is "Toggle Runway Centerlines" checked?
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
Old 10-13-2016, 06:12 PM
GalinHdz's Avatar
Yes. I even unchecked it and checked it again. I am thinking of reinstalling the app to see if that fixes the issue. This is the first time I have had any problem with FltPlanGo.
Galin
CP-ASEL-AMEL-IR
2020 Donation made
Old 10-13-2016, 07:44 PM
tomkk's Avatar
You might try support at fltplan dot com. I've contacted them a number of times and they've always been very helpful ...
Tom
Port Orange, Fl
EAA #51411
