Old 10-14-2016, 12:30 PM
DaleB's Avatar
DaleB DaleB is offline
Don, another 12 pilot in my EAA chapter pointed out that you can reach the canopy latch when you stand at the back of the wing. I felt a little silly after trying it... considering the dozens of times I crawled hoisted myself up on the wing to do it.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 10-14-2016, 01:23 PM
todehnal todehnal is offline
Originally Posted by DonFromTX View Post
Very interesting, I intend to have a get in and out party at the hangar using these suggestions. I don't think my knees and leg length will allow this one to happen, and most of all this would be done AFTER you crawl up on the wing to unlatch and lift the canopy. That seems to be the biggest obstacle, maybe a remote latch and lift like Joe has would be best.
Wow! I never thought about the canopy being latched while parked. As far as opening it, using the little lift tabs on the sides, makes opening the canopy quite easily. The only time my canopy is actually latched is when I am in it, and preparing for flight. Even overnighting when away, I just put the canopy cover on, over the unlatched canopy. Never had a problem operating this way........Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 10-14-2016, 02:49 PM
DaleB's Avatar
Mine latches itself when I close it; the latch flops around on its own. I plan to fix that when I replace the canopy this fall.
Dale
Omaha, NE
Old 10-14-2016, 03:08 PM
tomkk's Avatar
tomkk tomkk is offline
Yeah, mine too. I haven't found a way to fix it long term. Always seems to loosen up ...
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
Old 10-14-2016, 03:46 PM
rvbuilder2002's Avatar
KAI specifies squeezing the shaft of the handle to make it very slightly out of round so that it has some friction to stay where you put it.
Scott McDaniels
Hubbard, Oregon
Old 10-14-2016, 03:48 PM
Piper J3's Avatar
Piper J3 Piper J3 is online now
Originally Posted by todehnal View Post
No need to use the wing at all. Getting out is just a reverse procedure. The only tricky part is knowing exactly where the step is located, as you won't see it as you exit. You soon learn that it directly in line with the face of the instrument panel. It will take a few attempts.
Tell that to my wife... She missed step on exiting the 12 on April 20 this year. Been kinda a rough summer if you know what I mean.
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 10-14-2016, 04:16 PM
DaleB's Avatar
Yep. Tried that on the existing canopy when I had the handle out a few months ago, I obviously didn't squeeze it enough.
Dale
Omaha, NE
Old 10-14-2016, 06:50 PM
tomkk's Avatar
Did that. Worked for a while then eventually loosened up again. Maybe needs more out of round than I did ...
Tom
Port Orange, Fl
EAA #51411
Old 10-14-2016, 09:21 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
Earlier I put an O ring on the shaft under the latch. Worked fine until I converted to the locking latch, need to do that again.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 10-15-2016, 07:16 AM
joedallas's Avatar
joedallas joedallas is offline
Default Canopy Lock
Take a look at these pages
The photos are not up to date
http://joesrv12.com/Builder%20Log/al_04_01.htm
http://joesrv12.com/Builder%20Log/al_04_02.htm
Joe Dallas
Originally Posted by ben barron View Post
Would you share the specs of you canopy lift and keyless entry remote pieces?
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
