Don't understand
Bill,
I am not sure exactly what you are trying to do.
The tail spring is straight in the socket section.
There is only one bolt that holds the spring into the socket. The bolt head or nut is visible from the bottom of the fuselage.
The socket is sandwiched internally between two bulkheads.
To remove the socket, you would first have to remove the spring, then remove the 3 bolts from the rear bulkhead and then the 2 from the front bulkhead. The socket, which is a snug fit between the bulkheads should lift up and out through the access cover.
The spring is steel and the socket is steel so rust is likely.
This is a tough job as sticking your hand/arm through the access hole means you are feeling your way around because you can't see.
Good luck.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
