Old 10-08-2016, 08:00 PM
Default Show how you secured brake hoses
I am replacing tired aluminum tubing with braided hoses for the brakes. Would like to see pictures how to secure them to gear legs. Did you use any anti chaffing material over the hose?
Old 10-08-2016, 10:07 PM
Infidel's Avatar
Infidel Infidel is offline
Vlad,
I changed my alum lines to braid about two years ago. I used some good 3M electric tape to secure the line to the leg. Wrapping it about every eight inches. To date, the line is still secure and the tape is holding well.
Old 10-09-2016, 12:55 AM
Bevan Bevan is offline
A couple wraps of gorilla tape in three places around the gear leg for protection then a heavy duty tie wrap (zip tie) around the hose and gear leg.
Bevan.
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 10-09-2016, 04:19 AM
Steve Melton's Avatar
Steve Melton Steve Melton is online now
my braided lines have a protective plastic coating. I just leave them loose in the fairing and not secured. three years and no adverse condition. I have the small size tube with oversize fitting that mates to the caliper.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 10-09-2016, 07:18 AM
Vlad, try splitting some old air hose and using it where you want to tape it to the leg. A small piece won't weigh much and gives good protection to the leg and hose.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 10-09-2016, 09:55 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Unfortunately my just received hoses did not have the PVC covering.
I intend to simply wrap the whole length of the hose with spiral wrap and then use the tape method as mentioned in the plans. I wanted to use the smaller size tubing, but couldn't due to my need for a 45 degree fitting at the upper end - all -6's are different...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-09-2016, 12:15 PM
krw5927 krw5927 is offline
Bought a foot of cheap clear vinyl tubing from the hardware store, slightly larger than the brake hose diameter. Cut into 1-2 inch long pieces, then split lengthwise to fit over the brake hose. Used electrical tape on top of hose/tubing in 3 or 4 places down the gear leg to secure, just like the old hard line.
Kurt W.
RV9A
FLYING!!!
Old 10-09-2016, 06:50 PM
bruceh's Avatar
bruceh bruceh is offline
I did as described above. Vinyl tubing spit and then held in place with some electrical tape.
Bruce Hill
2020 VAF donator
Old 10-09-2016, 10:59 PM
What, you only got 4000 hours out of the aluminum???
I did it just like Bruce did, but secured with Gorilla tape. You'll love the braided hoses...a very straightforward solution.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 10-10-2016, 06:54 AM
Vlad---you can tape them or being the creative guy we know you to be, you 'coulc' take make some aluminum strips and wrap them around the gear leg, and rivet them in together. Wont move.
Tom
BTW---thanks for the great email!
Tom
Ridgeland, SC
