Old 10-07-2016, 08:53 AM
az_gila's Avatar
az_gila az_gila is offline
Question FAA Program Letter Q. - Phase I area
Guys,
I sent a draft copy of my Program Letter to the local MIDO office and got an inspector assigned to my plane.
In the letter I asked for a 100 nm radius - excluding PHX Class B and Mexican Airspace - as a Phase I test area.
This is a snippet of the email I received from the inspector.
...Most of the information looks good. I have a concern regarding the reason for the 100 nm radius for the Phase I test area. Is there a specific reason for this, or can you reduce this to 50 nm radius. Please let me know. Based on your answer, the program letter and appendices may need to be revised...
What have others done? And any good specific reasons to give her?
I will have to carefully review the extra area I requested, but I think it allows for use of other airports that are higher and lower to carry out landing/take-off testing at a larger spread of Density Altitudes.
Expected cruise speed might also be applicable, but I'm not sure how to state that..
Has anyone else had their requested area reduced?
She has given me her phone number and offered to discuss it today.
I have an Experimental FP Sensenich prop so I expect a 40 hr test period.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-07-2016, 09:02 AM
Mel's Avatar
Mel Mel is offline
Default Size of test area is dependant on aircraft speeds.
Typically for RVs other than the -12, I give a 75 NM radius. I will also offer a couple of airports up to 100 NM if you need to get to an airport for paint, transponder cert, etc. My office gives me pretty good freedom as long as I keep it reasonable.
Also remember that the radius does not necessarily have to be centered on your home airport, as long as it is within the area.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-07-2016, 09:09 AM
bret's Avatar
bret bret is offline
Never thought of that before, "not centered at home airport" my particular concern coming up is going to be able to test for climb and fuel burn #s from a lower altitude. we are near 5K elevation. Do we ask for this in the program letter?
Old 10-07-2016, 09:12 AM
az_gila's Avatar
Question
Thanks Mel, that makes sense.
Is there any FAA reference I can quote that would cover RV-6A speeds?
Gil Alexander
Old 10-07-2016, 09:14 AM
Mel's Avatar
Mel Mel is offline
Sure, you can ask for anything. Just try to keep it reasonable and give a reason for your request.
I often give a radius centered on an airport other than the home airport because we are so close to DFW Class B Airspace.
Old 10-07-2016, 09:15 AM
Mel's Avatar
Mel Mel is offline
Not really. Just common sense.
Old 10-07-2016, 09:23 AM
az_gila's Avatar
Question
One reason might be that it adds an airport at 799 ft MSL and one at 5153 ft MSL.
Home field is 2940 ft MSL.
With the Dynon Skyview data logging good measurements can be made of landing/take off performance at differing DA.
With 50 nm radius the airports are much fewer and limited between 4011 ft MSL and 1464 ft MSL.
Is that a good reason?
Gil Alexander
Old 10-07-2016, 09:29 AM
Mel's Avatar
Mel Mel is offline
Sounds reasonable to me. Her response doesn't sound negative to me. She's just wanting a reason for your request. Most ASIs that I work with are very reasonable if you just explain your reasoning.
Old 10-07-2016, 09:46 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Legs
The guy I used up in the Phx area is very familiar with RV's. The area I had was smaller. He increased it so I could get some distance for breaking in the engine. Also included 3 airports with restaurants.
Mine was Buckeye, Gila Bend, Ryan, Coolidge, Gateway and home. And, obviously everything in between. You should be able to get close to the same. Buckeye would give you a pretty nice straight run.
Sounds like you're getting close. Congrats!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 10-07-2016, 09:53 AM
az_gila's Avatar
Did he give you a radius or a "box" bounded by those airports.
Yep... very close, but recently held up by the passing of a BIL and the present visit of a nephew...
Gil Alexander
