Old 10-06-2016, 12:34 PM
woxofswa woxofswa is offline
Default Push pull control side mount
I have decided to add an adjustable oil cooler vent. Does anyone know of an existence or source for a side mount base for the push pull control?
Myron Nelson
Mesa, AZ
RV-10 N24EV
KITPLANES Contributing Editor
Old 10-06-2016, 01:19 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
I have five push/pull controls on the lower panel apron:
- Aft cabin heat
- Fwd cabin heat
- Engine Alternate air
- Oil cooler air (butterfly valve)
- Parking brake
If you have no room on the lower apron you could make a bracket out of 3/4"x1" 0.063 aluminium and attach the angle to the bottom of the apron. If not the apron you can mount the angle on the left side wire conduit cover.
Carl
Old 10-07-2016, 10:10 AM
I appreciate what you're saying l, but it doesn't really work with my configuration.
I was really hoping to put the control in the footwell either on the side of the tunnel or the outer sidewall. I thought I've seen a proper mount for side application, but can't find them now.
Myron Nelson
Mesa, AZ
RV-10 N24EV
