10-04-2016, 06:50 PM
Compression tester swivel connection?
I have the below model compression tester. As you can see, I have to rotate the entire red hose apparatus in order to screw in the compression tester hose to the cylinder. I want to put a small threaded swivel on the end of the red hose, so I can just tighten the swivel. Anyone know where I can get one? I know ACS sells the "rod type" connectors, but I don't want that if I can find a swivel.
10-04-2016, 08:07 PM
I removed the connector that screws into the cylinder from the hose and inserted another quick disconnect on mine. I install the connector into the cylinder spark plug hole then use the quick disconnect to connect the hose / compression tester. I tried to remove the quick disconnect from the gauge where the hose attaches but it was taking a lot of force and was afraid that I was going to break something so just added another quick disconnect connector.
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
10-05-2016, 05:14 AM
good idea. thank you.
10-05-2016, 06:49 AM
Aviation Dept. at Harbor Freight
Has all of the fittings you will need to add the quick disconnect.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
10-05-2016, 07:15 AM
Here is the best solution. Makes quick work without the frustration of fighting a hose or threading a fitting between the cylinder fins and baffles. It should be a mandatory item in any shop. In fact if you visit your nearest A&P shop I guarantee that one can be found there:
RV-8
(a few more airplanes too)
10-05-2016, 08:14 AM
That's the "rod-type" that the original poster didn't want. It wouldn't work well on my engine either as the baffles would be in the way. I can *just* get a spark plug socket and wrench on my plugs, there wouldn't be room for the rod on mine either.
Rob Prior
10-05-2016, 09:48 AM
Should not be a problem in the lower plug holes......
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
10-05-2016, 01:24 PM
Rigidly attached hose
works well enough as a "handle" to tighten the fitting into the spark plug hole, which is nice since you can't fit a crescent wrench in there onto the flats. I get enough leverage twisting that hose to seat the O-ring on the test fitting and get the job done. QD fitting inserted there would mitigate this advantage - but allow a deep-well socket to slip over the end - so almost a wash IMO.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
10-05-2016, 03:45 PM
I put a quick disconnect between the end of the jug connector and the red hose. Thanks again.
