I talked with Precision Airmotive yesterday and I'll get the replacement mixture arm that is a straight version.
The default one was a bent version. The bent one caused me to have to put a spacer between the arm and the mixture rod end bearing. Now the mixture rod end bearing will be in about the same position as it always has been but the arm will be tucked in and away from the interference with the cowl problem. The bent one had a .938" offset so you can see the difference that could make.
I still have to put that modification into the airbox itself to allow this lever to descend down below the airbox mounting plate.
I'm not sure if I want to change the lever direction at this point since the cable is pointed in the down direction for normal mixture cable push/pull.
Finally, I'll try to measure the clearance distance from the cowl with this arrangement. If I don't get that 3/4" or more distance, I might end up modifying that cowl too. At this point I may not need to do this however.
Scott
RV-9A - Oregon City, OR
flying since June 30,2018
2020 Dues paid
