Old 09-28-2016, 06:45 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Default Using Elevator Trim Indicator to Full Advantage
Until recently I have been using the elevator trim indicator on the D-180 to set and verify only takeoff trim position. Once airborne I would make trim adjustment for cruise and decent strictly by feel, which required many small, step adjustments to reach hands-off pitch stability.
I have made mental note of where trim indicator needs to be to satisfy cruise and power-off glide with full flaps deployed. Now when I change from climb to cruise and from cruise to decent I can quickly attain stabilized flight in pitch by setting the elevator trim by visual reference to the trim indicator. By roughing-in the trim setting visually I can attain desired pitch stability quickly with just a few small step adjustments and thus minimize workload.
So for what its worth (and maybe I’m just late to the party as usual) I thought I’d pass along this revelation as I gracefully age in my love of flying…
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 750
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 09-28-2016, 11:14 AM
rvbuilder2002's Avatar
Based on the location you are indication for cruise trim and the position of your take-off trim indicator, I would say that your indication is not properly calibrated.
The take-off indicator is normally about 1/8" below the mid point mark, and cruise position is typically about 1/4 of the way up from the bottom.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 09-28-2016, 11:28 AM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
Ditto on what Scott said. That's exactly how ours is trimmed.
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 630 Hrs on the Hobbs
Old 09-28-2016, 02:29 PM
DHeal DHeal is offline
Ditto what was said above. I use the trim indicator bar to initially set my trim for takeoff. After that, I virtually never look at the trim indicator again during flight. I suggest that one should be trimming in-flight to remove control pressures from the stick -- not pre-setting the trim for a future flight condition or "flying " the plane using the trim alone. During my application of flaps, I position the flap handle and then initially adjust the trim by pushing the trim switch and counting a suitable number of seconds - then fine-tune it if needed to achieve the desired airspeed and control pressure. Works for me!
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,080+ hours (as of Oct 2021)!
VAF donation through June 2022.
Old 09-28-2016, 02:31 PM
As noted, the cruise position will vary with how much and where you are carrying passengers or baggage, as well as airspeed.
Old 09-28-2016, 04:23 PM
PilotBrent PilotBrent is offline
I generally agree with that too. Would add that after putting in the first setting of flaps in the pattern I move the trim to the takeoff position which usually fully removes pressure from the stick - if I have to do a go around, I want the trim setting for takeoff to eliminate the need to adjust it when I'm focused on climbing out.
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
2021 VAF Donation, please make yours too!
http://www.mykitlog.com/brent45
Check out & subscribe to my Youtube channel for latest RV-12 flying videos...
https://www.youtube.com/channel/UCxQ...Px2I7jmazGdLqg
Old 09-28-2016, 05:46 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Ditto...if something happens, I want to be set up for go around. Full throttle drop one notch of flaps; eyes on my route out!!!
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 09-29-2016, 04:47 PM
sblack sblack is offline
Does that result in being out of trim with landing flap and approach speed? If so, are you pushing or pulling on approach?
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 09-29-2016, 04:51 PM
I would add that the trim setting for take off will vary considerably with CG. On big airplanes there is a "green band" which covers the full CG range. if you are in that band your stick forces will be acceptable if your CG is anywhere within the envelope. If you set your trim based on a chart in the AFM you will be bang on at V2+something, the all engine safety speed. So there isn't one setting that is good for all conditions.
The trim should be set to trim the airplane at your best climb speed, although again it will vary with CG somewhat so some adjustment will be required. But for takeoff, especially with a tandem RV (4 or 8) where the CG variation is large, the takeoff trim setting will only be a guideline.
Scott Black
VAF dues 2020
Old 09-29-2016, 05:35 PM
Phantom30's Avatar
Hasn't caused me any problems.. I find the control force so light..not an issue. Take-off trim setting has worked fine in all cg configurations for me.
The -12 is about as easy to fly as any plane.
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
