Old 09-25-2016, 09:58 PM
sbalmos's Avatar
sbalmos sbalmos is offline
Default Vans FAB mount plate to farther back throttle body?
Hi all,
Well, with the engine on, now starts the greater head scratching. My engine is an older model IO-320 that has a sump with a vertical oil pickup tube. Thus the screen access is in the center of the sump, and the throttle body is farther aft. To my chagrin, this makes the normal Vans FAB mount plate, and maybe the whole FAB, interfere with my nose gear. Suggestions?
https://photos.google.com/share/AF1Q...FZTDN4aUUzOUV3
I could probably just order a Sam James MK3 ram air kit. But then I'd have to swap my shorty James cowl for a longer one, buy the longer Sabre prop extension, etc etc etc. not impossible, but annoying.
Scott Balmos - RV-9A N112SB
Cincinnati, OH, KHAO
Old 09-26-2016, 06:25 AM
RV6_flyer's Avatar
Originally Posted by sbalmos View Post
Hi all,
It looks like you have an IO-320-B?? engine. The -B?? engine is NOT recommended on -A model RVs because the sump puts the FAB into the nose gear. The fix is a sump / intake tube replacement to make the engine work.
Here is a link to one thread that talked about the issue.
... and a 2nd thread with same issue.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-26-2016, 07:19 AM
sbalmos's Avatar
No, actually it is an IO-320-E1A. But now I'm going to have to back-track through the E1A's lineage to see if it's really designed from a B? series. My immediate concern would be if I swapped the sump, this series engine has the vertical oil pick up tube. Wouldn't any sump have to have a rear-mounted throttle, in order for there to exist the screen access port for the vertical oil pick up?
Old 09-26-2016, 09:09 AM
sbalmos's Avatar
Just talked with Scott at the factory... Yeah... Looks like I'm going to have to do research and convert the sump to a "normal" straight riser sump, with different induction tubes (which will have to be rewelded by Robert at EFII), and removing the vertical oil pick up tube inside the sump.
Scott confirmed this affects whatever engines have the vertical pick up tube, and thus a non-straight sump.
AAAAAARRRRRRRGGGGGHHHHH.
Old 09-26-2016, 09:29 AM
Mel's Avatar
Mel Mel is offline
Remember what Rosanne Rosannadanna said, "It's always something!"
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-26-2016, 09:32 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Nose gear vs. induction........
Switch to a tail wheel??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-26-2016, 09:34 AM
sbalmos's Avatar
Uh, *NO*. :P
Heck of a way to start a Monday. I'm also leaving out the part that while mounting the engine, I dropped said throttle body on my 2-week-old phone, turning it into a great Halloween-appropriate spider web.
Large ups and downs... *sigh* Oh well. It's only time and money.
Old 09-26-2016, 02:59 PM
sbalmos's Avatar
Looks like Larry replied, but it's not showing up in the server. Copied below from my notice email.
---Quote (Originally by sbalmos)---
---End Quote---
I don't think so. I purchased a 320-B1A with the sump you are referring to. The desirable sump (central intake area) has the pickup cavity formed into the sum and a protrusion on the aft wall of the sump. This cavity appears in the upper flange of the sump. If you look at your accessory case, you will find a threaded hole in the lower flange surface with a hex plug in it (this aligns with the sump's cavity). Simply remove that hex plug and make a metal cover for the area where your original sump tube connects. Be sure to use a good washer here and locking bolts.
Larry
So, I think I see where this is going. Below is a pic I took weeks back when I last had the sump off for other reasons. I recognize the hex plug in the rear flange of the accessory case now. And I've seen multiple ideas for the block off plate of the vertical tube's hole once that's removed. So it's a matter of finding a proper sump (in progress), new tubes (found), probably a different pickup screen according to the parts catalog, and any misc random gaskets and such. The plan is starting to come together.
Old 09-28-2016, 09:28 AM
lr172 lr172 is offline
sorry. When I wrote that, I thought you were having a problem converting to the other sump feed. I later realized your concern was about re-welding the intake tubes, not the oil pickup, so I deleted it.
You will not need a new pickup tube. The oil collection / feed in cast into the sump. You'll just need a screen, which should come with the sump you buy. The main sump gasket will have the hole in it. You just need to fabricate a plate for the back of the accy case. I made one from a piece of steel. SHould only take a 1/2 hour to make and mount. Be sure to look on ebay. I found a sump with intake tubes for $200 and sold my old one on ebay for $180.
Good luck,
Larry
Old 09-28-2016, 09:46 AM
sbalmos's Avatar
Yeah, bought a sump and tubes from my local salvage guy last night. And yeah, I understand the horizontal intake flow process now. Just have to find a proper piece of scrap steel now floating around the airport.
