  #21
Old 09-27-2016, 06:32 PM
sstocker31 sstocker31 is offline
Thanks to all that have replied, your imput is appreciated.
I had decided on the ECI Titan jugs as my choice, it seems that most of the ones with the failures are the big bore Continentals, and not the smaller Lycoming 320's.
With everyones input though, I will take another look at the Lycoming factory jugs....
Thanks guys....
Old 09-28-2016, 05:20 AM
MarkW's Avatar
MarkW MarkW is offline
I have a IO-320 ECI built by Titan three years ago. Love the engine, break in was quick and oil consumption is 25-30 hrs per qt.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 09-28-2016, 06:02 AM
Tom Martin Tom Martin is online now
For ten years I struggled with ECI cylinders. Delamination of rings after about 300 hours, oil consumption always high. Last spring they were rebuilt again and in 60 hours, never broke in. After 50 hours of blow by I started to make metal. 10 hours later, more metal, and we pulled a jug and found a cam bad. It had been fine previously, and I blame contamination of the oil with blow by and delaminating rings.
I used the recommended oils and breaking procedures each time.
The engine has been rebuilt, cam, bearings etc, and six brand new lycoming jugs
Break in was normal, low oil consumption, and a clean belly for the first time in ten years.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 09-28-2016, 06:45 AM
RV6_flyer's Avatar
Not all ECI Titan Cylinders are made the same. Here we have the ECI Titan STEEL cylinders with low oil consumption (like I have) and ECI Nickle+Carbide cylinders that use lots of oil. (or at least everyone I know that used them has had high oil consumption at some time between overhaul)
In addition to the two different cylinder barrel interior surfaces, there are also two different exterior barrels that ECI uses. Have not heard of any difference in the exterior barrel with tapered fins having issues other than the weight they save.
I am of the opinion that that the Nickle+Carbide cylinder barrels should be avoided on airplanes that are flown regularly. The only advantage may be better corrosion protection in an engine that resides in a corrosive environment and not flown regularly.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-28-2016, 07:31 AM
n816kc n816kc is offline
Default Superior, they may be
my Superior cylinders have been great from day one. break in was accomplished in the first hour, 1 qt oil used every 25-30 hours since. 380+ hours and going strong. I would definitely buy them again.
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2019 =VAF= donor
Old 09-28-2016, 08:43 AM
Same here.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 09-28-2016, 08:58 AM
bret's Avatar
bret bret is offline
Has anyone tried the AX 50? http://www.heavy-fuel-engines.com/wp.../ACE-AX501.pdf
Old 09-30-2016, 04:36 PM
halogen halogen is offline
I would also be keen to know what people think of these AX50 cylinders? I think the AX50 cylinders are what ACE use on their engines. On paper they look good.
Old 10-01-2016, 06:00 AM
bret's Avatar
Hey welcome to VAF, I was talking to Kevin Eldridge about his setup and almost went that route before I found my engine prop setup, if I had the extra money I would have went that route, I like the design and maybe after some time on his engines get logged, I might try a set. He is making some good HP #s
Old 10-01-2016, 07:30 AM
DanH's Avatar
DanH DanH is offline
With everyones input though, I will take another look at the Lycoming factory jugs....Thanks guys....
Forrest, how about posting the bottom line street prices you've been quoted in your research?
Dan Horton
RV-8 SS
Barrett IO-390
