Old 09-22-2016, 12:23 PM
RV7A Flyer's Avatar
Default Air dams and delta-temps
Experimenting with a little aluminum foil tape to find the right heights for the air dams before cutting them down and installing them (made mine removable), and found 1/2" results in a difference in CHTs of about 10 deg F between front and rear cylinders in level cruise at normal speeds. This is in comparison to 25-30 deg difference without the tape. The only issue with this is that the front ones tend to get a bit hotter during initial climb (just over 400, unless I shallow out the climb considerably, or step climb, either of which is manageable).
What would you consider a realistic goal for getting the temps matched up? 5 deg? 0? I.e., how much "polishing the cannonball" should I do here?
TIA!
Old 09-22-2016, 02:12 PM
airguy's Avatar
airguy airguy is offline
I'd be quite happy with a 10 degree delta, for me I see about 30-35 delta in a hard climb and about 20 delta in cruise with the front cylinders cooler.
Old 09-22-2016, 02:40 PM
bret's Avatar
bret bret is offline
How much of the original air dam are you guys flying with, trying to decide if I need to trim some before first flight?
Old 09-22-2016, 03:05 PM
RV7A Flyer's Avatar
I put them on for the first flight, and took them off immediately after...much, much too large, blocking too much airflow to the front cylinders.
I haven't had them on now for 400+ hours, but decided to start messing with this a few weeks ago.
I'd leave them off entirely for the first flight and see what you get. And, one of the best pieces of advice I got during the build...make them removable, with screws and platenuts, NOT riveted in!
Old 09-22-2016, 03:07 PM
bret's Avatar
that's what I did, removable for trimming.
Old 09-22-2016, 03:17 PM
I removed them completely, after a couple of iterations of cutting them down.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 09-22-2016, 09:04 PM
airguy's Avatar
I've got the stock air dams trimmed about 1/2" lower on mine.
Old 09-22-2016, 09:13 PM
lr172 lr172 is offline
I pulled mine, but after getting everything sorted out and broken in, I could probably use a small dam for my #1 jug.
Larry
