Old 09-22-2016, 10:19 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Default Identifying ECI and Superior Cylinders
Any quick way of telling these apart?
One we have here has "PM" stamped inside the rocker cover area and has wider, squared off rocker shaft bosses plus thicker cooling fins compared to a stock Lycoming 360 jug.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 09-22-2016, 06:28 PM
Randy Randy is offline
MY IO-375 from Aerosport has ECI jugs and I think the most telling difference between these and other brand cylinders is the fact that the fins taper down from mid jug to the bottom, forming a conical shape that does not fit vans cylinder baffles very well
Maybe there are some other way to tell?
Old 09-22-2016, 06:35 PM
Kyle Boatright Kyle Boatright is online now
They also sell cylinders with a "normal" fin arrangement.
I would think there should be a S/N or part number etched or stamped on the cylinders. You should be able to trace that number to the manufacturer.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-22-2016, 07:35 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Part numbers
In general -
ECI parts prefix with AEL
Superior prefix with SL
The part number is stamped on the cylinder somewhere, this shows an ECI location -
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
