  #11
Old 09-22-2016, 01:04 PM
istrumit's Avatar
istrumit istrumit is offline
Originally Posted by Bill Boyd View Post
Thanks for the owner report, Scott. This is going to be so awesome!
Somewhere between two and ten years to go on my build. Worst case, I'll be Jay Pratt's age when she flies
The RV-10 is seriously an awesome machine...
Scott Martin
N430WP RV-10 - Purchased
Old 09-22-2016, 01:08 PM
istrumit's Avatar
[quote=rleffler;1113569]One trick that helped me quite a bit, is to put one or two AN960-10 washers on the screw on the rear baffle corner. Place the washers between the baffle and the engine.
Bob - I failed to mention that this airplane has a plenum...will your idea still apply ? I would like to get 2/4/6 a little cooler also.
Scott Martin
Old 09-22-2016, 01:28 PM
Auburntsts's Avatar
Auburntsts Auburntsts is online now
[quote=istrumit;1113673]
Maybe. The idea is to open up space around the rear cylinders for air to flow where there's no cooling fins and little space between the cylinders and the baffle walls. See this thread for in-depth info: http://www.vansairforce.com/communit...ad.php?t=37835
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 09-22-2016, 01:52 PM
myrv6180 myrv6180 is offline
Default Flying the RV-10
If you are by yourself, don't use full flaps and you will find you don't need as much up trim or back stick.
rleffler's Avatar
rleffler rleffler is offline
Todd answered your question. It will clearly drop #5, and #3 dropped about half of the #5 drop for me. That and reducing the air **** up front took care of my issues.
You can do the same on the left side, buy you have to be a little more creative on how to rig it. Many more accessories in the way and screws in different locations.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 09-22-2016, 01:57 PM
Default RV-10
Only use half flaps when no rear passengers or luggage. Then you will need less up trim or back stick when landing.
Old 09-22-2016, 01:59 PM
istrumit's Avatar
Good idea...
Scott Martin
Old 09-22-2016, 02:00 PM
istrumit's Avatar
Got it...thats a great explanation...I will be giving it a try.
Scott Martin
