Old 09-21-2016, 08:43 AM
lr172 lr172 is offline
Default Question about static leak and ASI
I worked on my static setup in phase I and got within 2 MPH of the GPS numbers (4 leg test). Recently I noticed my IAS reading higher than expected. I ran a couple test runs and am reading about 5-7 MPH high.
At my annual I moved one the soft vynal lines attached to the rivet to be sure that I had Good drainage. I am suspecting that I disturbed the RTV seal and caused some leakage. I taped off one port and used a hose to test. I am seeing about a 100' loss of altitude in about 20 - 30 seconds. I thought the standard is 100' in one minute. Is this type of leakage enough to cause a 7 MPH error in the IAS?
Larry
Old 09-21-2016, 10:38 AM
vic syracuse vic syracuse is offline
Super Moderator
Yes, a static leak will cause the airspeed to read high, especially if it is in the aft fuselage where you mentioned it. Most of our cabins are at a lower pressure than the outside air due to the airflow. You can see this effect by opening your alternate static vent while in flight---both the altimeter and the airspeed will increase.
Yes, the 300 FPM leak that you have is not in spec for an IFR cert.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
