Old 09-20-2016, 05:34 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Default Dear Mr. Lycoming, why is the cam so high up in the engine?!
What is the trade-off? Why did Lycoming put the cam on top and every other flat engine manufacturer (Continental, Franklin, Jabiru, VW & GM/Corvair) put it on the bottom where it stays nice and happy bathed in oil when we neglect them?
This seems like a pretty big flaw. I've always wondered this.
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Old 09-20-2016, 05:58 AM
pierre smith's Avatar
Default Nope
They're not 'bathed' in oil. The oil level is way below the cams on Continentals...they're all splash oiled, except for the bearings which are pressure lubed.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 09-20-2016, 06:02 AM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
Maybe we're putting the engines in upside down???
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019 donor and happy to do it.
Old 09-20-2016, 06:57 AM
aturner's Avatar
aturner aturner is offline
Don't know the answer, but the O-145, Lycoming's first boxer, had the cam down low:
https://en.m.wikipedia.org/wiki/Lyco...g_O-145_B2.jpg
-Andy Turner
RV-10 N784JC
Old 09-20-2016, 07:07 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Maybe Mahlon will give his valued opinion.
P.S. Mahlon Russell, where are you?
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 09-20-2016, 07:08 AM
6 Gun 6 Gun is offline
Thumbs down cam
Just overhauld a Perkins diesel that was 32 years old and all its life has been in a boat on the ocean in a damp hole in the bottom and not a spec of rust on the cam.Maybe the Lycoming cam is made from wrong type of metal also the valve train in the Perkins is set up with more pressure than Lyco turns same RPM @ 2700 and no cam spauling.Go figure.
Bob
Old 09-20-2016, 08:20 AM
BillL BillL is offline
Default Musings
An engine design is a tangled mass of tradeoffs and contractions. Very few are a clean sheet design, and even they have compromises for fitting manufacturing machinery on hand and other influences for commonalities of volume production for lowest cost.
A loop flow combustion chamber (both intake and exhaust on the same side) means pushrods are better located on the opposite side. Aero engine designs always want to have holes in the bottom to prevent a cylinder from completely filling with liquids, oil or fuel.
So - there is no magic reason for the cam to be located high as far as I have ever been able to determine. Lubrication is not an issue either way. Lycoming has done other odd things design wise, I honestly think that if it were not for a better parent company, they would not have ended up the prime supplier of engines today.
If our engines had positive crankcase ventilation the cams would probably not have corrosion problems. PCV is very problematic for the operational profile and its failure modes, so there are some other strong reasons it is not incorporated. It is not water that is the real issue, it is sulfur in the fuel. Sulfur has been removed from nearly all world fuels worldwide as it interferes with catalytic reactions and would make sulfates . . . . . . not good. Regardless, we have methods of preventing corrosion.
Litigation and certification is tangled in there too as they drive some very odd decisions and are in many ways an impediment to improvements. " Mr Lycoming, I see you improved your connecting rod. That means the previous design was inferior and you were hiding it. Ladies and gents of the jury . . . "
Bill
RV-7
Lord Kelvin:
Old 09-20-2016, 10:59 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
If you storing it as a core for a long time, then upside down is best with the case full of oil.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-20-2016, 11:49 AM
rv7boy's Avatar
Forum Peruser
In addition to the location of the camshaft, which is the original topic, I am also intrigued by the decision to support the camshaft in a journal machined in the casting(s). When I saw my O-320 apart during an overhaul a few years ago, I was surprised at this. Is this common practice for all aircraft engines?
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 09-20-2016, 11:57 AM
Mel's Avatar
Mel Mel is offline
If you are referring to the fact that the cam does not ride in bearings, since all loads on the cam are from the lifters and their force is from opposing directions, there are practically no loads on the bearing surfaces. Therefore bearings are not needed.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
