Old 09-19-2016, 11:41 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Default What psi are you guys spraying Azko?
Inquiring minds want to know.
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2019
Old 09-20-2016, 05:49 AM
Nova RV Nova RV is offline
It would depend on your spray gun more than anything. I use a cheap Harbor Freight HVLP detail spray gun at about 20psi. You can find identical ones on EBay for $12- $15. I have an old Badger detail spray gun I tried and at 20psi it would only dribble and spit out the paint. It's an older non HVLP type and likes 40+psi.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 09-20-2016, 07:39 AM
mike newall's Avatar
mike newall mike newall is offline
Most of the regular priced (economic) HVLP guns are designed to run at 40 psi at the gun.
I run the shop at 90 psi for tools and have a tee split off from an outlet through a separate water trap and regulator that drops it to 40 psi.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 09-20-2016, 08:07 AM
wirejock's Avatar
wirejock wirejock is offline
Default Instructions
The instruction sheet should have starting settings. My DeVilbiss is 23 psi but also important is the flow and fan controls. Too much paint, splatters. Too little may take forever to coat. Too wide a fan wastes paint, too narrow may go on too thick.
If you describe the results, someone may be able to advise on adjustments.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 09-20-2016, 08:54 AM
Av8rRob's Avatar
I'm spranying with the purple HF gun. My last spray was at 20 psi but came out a bit grainy, I guess in need to play with the adjustments more.
Rob Lasater
Paid Dec 2019
Old 09-20-2016, 09:31 AM
wirejock's Avatar
Default Grainy
Grainy, I would increase pressure first then if still grainy, reduce the paint flow a tiny bit.
Also, it helps a lot to have a really good regulator at the gun for consistency.
Microair is awesome. Never moves so pressure stays exactly where it's set.
Larry Larson
Estes Park, CO
Disclaimer
Old 09-20-2016, 12:13 PM
rapid_ascent rapid_ascent is offline
I use the cheap HF gun for shooting Azko. I have the version with the pressure gauge on the gun. I think this is very helpful if you don't have it there I would suggest you add one.
The pressure that is important is the pressure once you pull the trigger. This end up being pretty low even with a relatively high pressure beforehand. I think mine is somewhere around 40PSI. Again the number that I look at is the pulled trigger PSI which ends up being between 5 and 10 PSI. I tune it by testing my pattern real quickly before each session.
The other thing that I have been doing is adding a very small amount of lacquer thinner to the mix. Also make sure you pour the paint through a filter as you pour it into the cup.
I just shot a batch over the weekend and it turned out great. I hate waiting the 30 minutes once its mixed by otherwise its works out great.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 09-20-2016, 12:53 PM
Av8rRob's Avatar
Thanks guys, I increased the pressure and it came out much better today.
Rob Lasater
Paid Dec 2019
