Old 09-18-2016, 06:55 PM
BruceMe's Avatar
BruceMe BruceMe is offline
Default Rudder counter balance weight
The swap I did on the rudder didn't come with the rudder counter balance lead. This is the first generation smaller counter-balanced RV-7 QB rudder.
Is this the right part?
E-614-020
Thanks!
[MODERATOR: This probably belongs in the RV-6 section, sorry]
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Old 10-10-2016, 04:09 PM
RV6_flyer's Avatar
E-614-020
Thanks!
Yes that is the correct part number.
My 19-year old RV-6 does not have the counterbalanced rudder that the RV-8(A) does. Yes some of the late RV-6(A)s were shipped with RV-8 Vertical and Rudder. The early RV-7(A) tail kits shipped with RV-8(A) rudders before they were changed to a larger rudder.
I am answering your post because I am now building an RV-8, built an RV-6, and am familiar with the part number you are asking about and how it is used on my RV-8.
The Elevator weight that you list above E-614-020 is the same weight used in the RV-8(A), -9(A), and -14(A) rudder. The RV-8(A) plans / manual that I have does not have you balancing the rudder to 100% but just adding the above weight. IMHO, one would need to double the weight to get close to a 100% balance. I am one that likes to build an airplane as light as possible and would be reluctant to double the rudder counterbalance weight to get 100% balance on a part that the designer does not require to be 100% balanced.
If I understand your question, you only need to add the weight to the rudder and no need to balance it with the addition or subtraction of weight. I would say that we are using a counterweighted rudder and not a balanced rudder.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
