As I understand it, on parallel valve Lycoming engines, a different rocker arm was used on intake and exhaust valves. Different part number for intake and exhaust. To save on parts inventory, a change was made to a rocker arm that would work on either intake or exhaust.
June 5, 1991 SI 1454 was issued about rocker arms.
Insert Text from SI 1454: (Note: copied from PDF and there may be errors)
Textron Lycoming currently specifies one (1) Rocker Arm Assy. P/N 17F19353 for both intake and exhaust on all cylinders that incorporate parallel valves.
The new rocker arm assembly supersedes Rocker Arm Assy. P/N LW-18790 which also was used on both intake and exhaust.
Prior to the aforementioned rocker arm assemblies, one (1) each of Rocker Arm Assy. PIN 69444 (intake) and PIN 74636 (exhaust) were installed. Rocker Arm Assy. PIN 69444 (intake) is identified by the oil drain hole located under the push rod end of the body. Rocker Arm Assy. PIN 74636 (exhaust) is identified by the oil drain hole located under the valve end.
CAUTION
ROCKER ARM ASSEMBLIES PIN 69444 AND P/N 74636 ARE NOT INTERCHANGEABLE WlTH ONE ANOTHER. ASCERTAIN THAT THE PROPER
ROCKHR ARM ASSEMBLY IS INSTALLED AT THE CORRECT LOCATION.
ROCKER ARM ASSY. PIN 69444 MUST BE INSTALLED ON THE INTAKE SIDE.
ROCKER ARM ASSY. PIN 74636 MUST BE INSTALLED ON THE EXHAUST SIDE.
EITHER ROCKER ARM ASSEMBLY, PIN 17F19353 OR LW-18790?, IS A DIRECT
REPLACEMENT FOR ROCKER ARM ASSEMBLY PIN 69444 (INTAKE) OR PIN
74636 (EXHAUST).
? These rocker arms must be in compliance with latest edition of Service Bulletin No. 477 (A.D. #87-10-06).
END Insert.
February 25, 2011 revised to SI1454A.
Insert text from SI1454A.
The supersedure history for the Rocker Arm Assembly is as follows:
LW18790 -> 17F19353 -> 17F19357
NOTE
Before reusing Rocker Arm Assembly P/N LW18970, refer to the latest revision of Lycoming Service Bulletin No. 477 (
AD 87-10-06).
NOTE
The new Rocker Arm Assembly P/N 17F19357 can be installed in either the intake or exhaust valve position without changing the other rocker on that cylinder.
END insert
Supplement 1 Insert:
This supplement corrects the Part Number in the following NOTE of Service Instruction No. 1454A dated February 25, 2011.
NOTE
Before reusing Rocker Arm Assembly P/N LW18790, refer to the latest revision of Lycoming Service Bulletin No.
477 (AD 871006).
END insert
SB477A list model number and S/N of engines that LW18790 rocker arms may be too thin and crack.
In other words, DO NOT use rocker are LW18790 in your engine even if it is Experimental.
Hope this helps.
