Originally Posted by grubbat
Dean, I may be wrong but I think the isolators are there if you run standard mags ignition, not Pmag. The Pmag will give 2ppm but not enough voltage for the EI tach. I think the EI tach will need to be modified by EI for a cost of 125.00 to be used with electronic ignitions.
Good luck.
Thanks for the reply. I just contacted EI with this concern. EI confirmed the isolators are only for conventional mags. However, they confirmed by part number, my tach is configured for electronic ignition. According to the PMag manual, pin 6 on the PMag connectors is available to drive a tach. The output is 12 VDC, 2 pulses per revolution. According to EI, this output is compatible with my tach. Now, I am more optimistic this unit will work...
Thanks again
